Question about Craftsman 25cc Gas Line Trimmer
Craftsman 25 cc Gas Line Trimmer 358- pull cord when pulled won't connect nothing happens.what is the problem?
erickg
  • 116 Answers
SOURCE: REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Posted on Apr 17, 2009
  • 420 Answers
SOURCE: Craftsman 17" 25cc Trimmer...pull cord stuck
it's doubtful that bad gas caused this, it sounds like the cord was back-lashed and partially came off the recoil pulley. Remove the recoil cover and ensure the cord is all on the pulley, make sure the rewind mechanism works smoothly before re-installing.
Posted on May 14, 2009
  • 149 Answers
SOURCE: My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Posted on Jul 05, 2009
rycgl
  • 1545 Answers
SOURCE: Replace fuel and primer line on craftsman
Try searching Craftsman Weed Trimmer fuel line on this site for numerous responses to this problem.
Posted on Aug 07, 2010
rycgl
  • 1545 Answers
SOURCE: can you recomend a cleaner
Any petroleum based cleaner added to the fuel will dilute the gas/oil mixture, thinning it and possibly not allowing enough lubrication during operation; if this is a 2-stroke engine. This is not recommended. Removing the carburetor and cleaning it is usually the best and accepted way to go.
You can do this on a 4-stroke engine and there are many, many choices for fuel system cleaners available for these. You just pour the cleaner into the fuel tank and run it. If this is a 4-stroke, then check for cleaners at your local auto parts store.
Posted on Oct 10, 2010
Yes, I have a Craftsman 25 cc Gas Trimmer and we just snapped the starter cord. Do you have to open up the head to fix this? Does it need a special type of cord?
Yes you have to remove the plastic recoil assembly and install a certain size cord. We use a #3 or 3.5 cord on all our string trimmers, blowers with that size engine.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
The head won,t turn
you will need to pull the head off, as it sounds like the cable is off. there should be four bolts/screws, there maybe some in the middle also, gently remove the head(this is the top of the trimmer where the pull cord is, once you have it separated you can turn the cable by hand and the line feeder should rotate, if it does then look inside the head and make sure it is still square and not rounded. or you can pull the line feeder off and pull the cord and see if the cable rotates, whichever you feel comfortable with trying. Good Luck Tim
May 16, 2011 | Craftsman 25cc Gas Line Trimmer
I NEED TO REPLACE THE STARTER CORD ON MY CRAFTSMAN GAS LEAF BLOWER MODEL NO. 358-797180
Try Sears...They sell/have appl. parts. You'll be amazed at what they have.
Apr 21, 2011 | Craftsman 25cc Gas Line Trimmer
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
May 07, 2009 | Craftsman 25cc Gas Line Trimmer
Apr 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Craftsman 25cc Gas Line Trimmer Logo
501 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
