IP address We recently started having problems losing internet connectivity. Once the connection is dropped, and we attempt to restart the router, modem, and our motorola vt1005v voice terminal, there is no dialtone on our phone. Many times during the startup, the LED blinks twice indicating that it needs an IP address assigned by the router. I've updated the firmware for the router to see if it would solve the issue, but no dice. We've not made any changes to either hardware or software prior to this problem.
  • daree Nov 24, 2007
    Suddenly I have no phone service thus I have no phone to call for help.....I try everything that Vonage sugges with no solution........I have unplugged, rebooted and waited lengthy times for emails from Vonage....I still sit with nothing
  • Anonymous Dec 22, 2007
    after setting up a new (used) computer, which uses the the same Windows xp. And now, I get only 3 up beeps, with no signel.
    I have unplugged the SpeedStream and the Motorola set for longer then 3 min. I pluged them back in and restet the Motorola for 30 sec on the back near the power plug. reOpened the inter net and still can not get the 192.168.102.1/admin.html..
    Please somebody help me! My other phone number in Mexico is (from the US) 01152 664 609-8157. Their 800 number does not work in Mexico.
    Desperate!!!!!
    Problem Solver:
  • 22 Answers
connect the computer to the Voice terminal VT1005v( WAN port)<---PC and check the ip address on the computer which should be "192.168.102.X". Open the web interface of voice terminal ( type in " http://192.168.102.1/admin.html " in the address-bar of your internet browser ). you can see the Restore Factory Defaults button and click on it. So you can reset the device. After that, reboot the your whole network.
hope this will fix your problem
Posted on Oct 25, 2007
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
I keep losing my connection
you sound like youve covered the basics. are you certain you are using the correct power adapter? might be getting too many V's or mA's. try the firmware upgrade.
Jul 30, 2012 | NetGear WGR614 Wireless Router
Lost my IP address from zyxel
According to me there are two reason for not connecting to internet through your ISP.
1. Configuration setup might have got deleted
2. Driver files may be corrupted
An important thing to know is We would not lose our IP address.
Static IP address wouldn't be changed while restarting our modem,
Dynamic IP address changes on every restart of our modem. To know the Current IP address the following URL will be useful to you. http://www.ip-details.com/
Jul 25, 2012 | Zyxel P-2602HW Router (P2602HW)
Internet connection problem in ubuntu
That depends on the modem and router settings. If you are using cable modem (a box connected to the cable from your internet service provider) without a router, you will need to set your computer to get a IP address automatically and restart the modem. Then you can renew the IP address if necessary. If you are using a router (another box) connected with the modem, then you might want to connect to the router by using the IP address on the same subnet as the internal interface of the router and enable DHCP. Then you can restart the modem and get an IP address for the router (usually you can see a button to click for that on the management page of your router after you open that in your browser, check the manual of your router about details). After that you can reconfigure your computer to use dynamic IP address and then renew IP address or restart. Please don't hesitate to post if you have questions.
Jul 11, 2010 | Canonical Ltd. Ubuntu
Troubles connecting WRT160Nv3 Linksys router to Wii
I am thinking the router was set to get it's IP from the modem and when you changed the IP after the power failure, is when you problems started. I suggest looking at your networks IP addresses. I think they are not on the same subnet.
My first step would be to record the settings and do a hard reset on the router, then proceed to reinstall the settings and make sure your network is on the same subnet.
Dec 14, 2009 | Linksys WRT160N Wireless Router
Intermitant signal
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it. now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close. restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it. now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 11, 2009 | Arris SURFboard SBG900 Wireless Router...
Connection keeps cutting off
Hi, I have also faced the same problem many times....
Try to restart the router and see for the connection light to turn green.... then connect to internet..
This happens due to heavy load. When thre are many users your router will restart automatically.
If this still continues ask your tech guy to change the line.
Feb 01, 2009 | Westell Wirespeed VersaLink...
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Netopia losses connection to internet and to server and vp phones
The Netopia Is a business-class router. Not clear from you question are you running Small Business Server or Windows Server 2003? If its the former, it has a wizard that will configure your LAN & the Netopia.
You can configure the Local IPs on the Netopia in the DHCP settings in expert mode.
The VP (VOIP?) phones are acting as a DHCP server & re-configure the network to their defaults.
Any 1/2 decent IT person (witth some real qualifications) could figure straiten this out...beware of "Techs"
Mar 04, 2008 | Netopia (3347NWG-VGX) Wireless Router...
Constantly losing connection
A wireless router if set at enable DHCP will always asign an IP address to each pc, and keep it, it will not alter until the next time your connected, and even if the first pc that you connected with, first next time, it will get the same ip address allocation. The solution may be that your router is set to disconnect from the internet after a period of innactivity. Go into router settings and look for something similair to (Idle connection-Never).
Jan 06, 2007 | NetGear MR814 Wireless Router
Computers & Internet Logo
1,398 people viewed this question
Alun Cox
David Payne
David Payne
