Nokia 6600 Cellular Phone
Problem for Nokia 6600
6600 nokia
By roelito on Oct 16, 2007
when i attempt to charge my cellphone and turn it off, and when it is charging already, there's a words that would come out and says " application closed main" what is the problem of my cellphone? please help me to remove this problem.......thanks
Comments:
Oct 18, 2007
how can i lock my fexplorer for not to let others to open fexplorer?
please help me with this problem thanx....
Oct 20, 2007
- when my phone received message emediately the "application closed ncnlist message" appeared now what is the problem of my cellphon? thanx
Best Solution
posted on Oct 17, 2007
Helpful)
bigjohn007
Rank: Wiz
Rating: 79%, 184 votes
if this always happens.. try resetting your phone by typing *#7370# it will reformat your phone to its orig settings. warning... all your saved data will be lost like messages, pictures, videos, etc...
this way will refresh your phone to its original settings...l
Was this helpful?
Yes
No
Solution #2
posted on May 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.)
NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting!
This is "only" a soft format...
Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
Proceeding: Equipment switch off, which keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
If that does not function, then equipment for 1 hour switch off, Akku so for a long time rausnehmen and again try.
"only" virtual the memory is generally cleared - genuine formatting can take place only in a Nokia service center, if the Fash is deleted there and/or new L.G. is installed.
Popular Solutions for Nokia 6600 Cellular Phone
Questions and Unsolved Problems for Nokia 6600 Cellular Phone
Do you recommend Nokia 6600?
Answer
Answer
how to repair nokia 6600
Answer
where can I get a manual for my sanyo 6600
Answer
can you send me the unlock key of my x-plore 1.35? This is my serial no. 359350022729764 pealse send... (More)
Answer
355740023024591 it is my device no i want unlock key of xplore 1.35 s60v3
Answer
i need a free restriction code for nokia 6085
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular... Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
