Disk drive wont read Ubuntu disk
I bought an Ubuntu magazine, I was thinking of switching. After doing enough research I decided to install it (using the disk that came with the magazine). I tried it on an older computer first to make sure I could do it right and that the disk worked. It installed fine, had little problems with it.
When I popped the disk into my computer it won't load. To test my drive I put Civilization 3 in and it loaded just fine. I really want to install Ubuntu on my computer but for some reason it won't load the disk, I'm not really sure whats going on but any help I would really appreciate.
Thank you
  • 433 Answers
Make sure you are booting from CD-ROM and not the hard drive, If that doesn't help get out your windows CD...run it until right after it formats your hard drive then stop your computer and boot with the Ubuntu disc...
You will love Ubuntu...it clean not bloated, straight forward, plenty of free help and software, everything you want is available -free and works better.
...good luck (there is a learning curve, but not bad) please leave rating
Posted on May 16, 2009
Do I need a new hard drive for my acer d260?
It sounds more like you haven't installed ubuntu correctly. Why do you think the drive is faulty, was it giving drive errors before you loaded ubuntu? Does the bios have s.m.a.r.t. disk checking enabled?
If you can get back into ubuntu perhaps by booting off an ubuntu disk you can check the disk - here's how How to run checkdisk
If not take the drive out get a sata to usb converter and run a disk checking utility on a friends machine
for example chkdsk space diskletter colon space / f
chkdsk e: /f
Microsoft Corporation Smartmontools Community Help Wiki
May 13, 2014 | Acer Aspire One D260 Netbook
How to fix a disk boot failure
download ubuntu. copy it onto a dvd as an .iso that will then be used as a bootable disk. Install this disk in your cd/dvd drive. Turn on your pavilion and go into bios to make sure the DVD drive has boot priority. Once you boot up into Ubuntu, you can access the DISK UTIL. Running this utility will offer you a way to read the "smart data" and thereby verify if your disk is physically damaged. IF the smart data shows any bad sectors, then try to do a back up and reinstall on a new hard drive. It's a long process but diagnosing the physical condition of the drive is the first step.
Feb 14, 2014 | HP Pavilion A730N (PJ510AA) PC Desktop
I have installed ubuntu on my iMac as I couldnt install windows or boot Mac os I have a external drive that has Mac os and recovery partion but I can't boot with it but in ubuntu j can read the disk I...
You could copy the contents from the external drive to the internal one. Boot from an external CD or DVD with the Ubuntu installation image on it. Doing so will allow you to write over the internal drive. Learn the dd command (start with "man dd" from your Ubuntu terminal window. An example might be "dd if=/dev/sdb of=/dev/sda"
"if" is short for "input file", but can represent the whole device (drive), which is what you want. "of" is short for "output file". You can use Ubuntu's Disk Utility to examine all your drives and figure out which one is which.
This is a very powerful command and nothing else I can think of can wipe out a disk you meant to keep any faster or more thoroughly, so be very sure you figure out which (sda sdb, and so on) is input and which is output. The "dd" command produces no output until it's done, just quietly working away on gigabytes as ordered.
Feb 03, 2014 | Computers & Internet
Installing Ubuntu Server on Dell Dimension 2400?
Step 1:
The Ubuntu Linux operating system is available either with or without a desktop environment. The version with the desktop environment is meant for personal use and includes word processing, email and graphic editing software. The version without the desktop environment is called "Ubuntu Server." The server version does not come with any graphical software or productivity software. There are three different desktop environments available for the Ubuntu operating system. The default is the Gnome desktop. The other two are the KDE and the XFCE desktop environments.
Log into the server. Type the command "sudo apt-get update" to update the list of software packages available. Type the command "sudo apt-get install ubuntu-desktop" to install the Gnome desktop. Type the command "sudo apt-get install xubuntu-desktop" to install the XFCE desktop. Type the command "sudo apt-get install kubuntu-desktop" to install the KDE desktop. Type the command "sudo reboot" to reboot the server. Ubuntu Linux Tutorials,Howtos,Tips & News http://www.ubuntugeek.com/install-gui-in-ubuntu-server.html
Mar 17, 2013 | Dell Dimension 2400 PC Desktop
I have a single installation of Ubuntu 11.10. How do I remove it and install Windows 7? Have tried from the Windows boot disk but I dont know what my drive letter is as Ubuntu does not name it????
You can use the windows disk to over-write the ubuntu installation. Just boot from the windows disk, and when it asks where to install, tell it to format the disk and create a partition from the unpartitioned space. Windows will format the disk and you should be good to go. Keep in mind, everything on the disk will be lost.
Jan 19, 2012 | Canonical Ltd. Ubuntu
I just let my credit card information in a few minutes ago.i have a blank hard disk and am rying to install Ubuntu.iso on a hard disk using an emergency disk fom Windows to boot up the system with cd...
If you have the 'ubunto.iso' file, you need CD/DVD-writing software to read that ISO file, and to burn that image onto a blank writable disk.
Then, restart your computer, and change the "boot-order" so that the CD/DVD device is the _FIRST_ boot-device. Then, Ubuntu will boot-up, and you can "install" Ubuntu onto your disk-drive.
Jul 03, 2010 | Computers & Internet
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Dec 19, 2009 | Computers & Internet
How do I reformat my computer, because it will not boot up for me to be able to erase the data on it?
If you bought the netbook brand new then in the box you should have a Windows XP Home install disk.
Now because you have not got an optical drive (CD/DVD) in the computer you will need to get yourself an external CD/DVD drive and connect it up to the computer. Pop the disk in the drive and restart your computer. Hit F12 as the computer starts up and select the external drive as the first boot drive. Then you can proceed to re-format and reinstall the operating system.
If your computer has Linux as the operating system you should have a Ubuntu install disk in the box. If you don't you can download the disk free, you are just going to have to use another computer to download Ubuntu and burn it to a disk. Just follow the instruction to boot from the external CD/DVD drive to install it.
Get Ubuntu here >>>>>>
http://www.ubuntu.com/GetUbuntu/download
Regards.
Sep 29, 2009 | Acer Aspire One A150-1006 Notebook
Install ubuntu and vista at the same time
You can actually install unbuntu "inside" windows is what they call it. Essentially you install it while logged into Vista, tell it how much space of the hard disk you want it to use, and it's done. All you may want to do is a disk fragmentation. 1.5GB probably wouldn't be enough if you truly want to use Ubuntu.
Apr 24, 2009 | Toshiba Satellite A215-S7437 Notebook
Computer- reformat
In order for the computer to work, and for you to reformat the harddrive, you will need a bootable disk, either one which has a drive utility on it in order to reformat and partition the harddrive or an operating installation disk which includes a drive utility (any windows installation disk has it) - without one you will neither be able to properly reformat the harddrive nor install an operating system on it in order to use the computer.
As you have stated, this is obvious, and your problem is that you do not have an installation disk. A restore disk would not help if you reformatted the harddrive.
You can either purchase a Windows operating system disk, find one (no, not anything illegal - I have spare copies of windows and all of my geek friends have spare copies, because frankly of issues like this),
or download a copy of Linux and burn it to a cd - Ubuntu is a decent choice for a starting Linux user, and is very easy to use (works alot like windows, has tutorials, etc) and is completely free - you can do a search for Ubuntu Linux on google and you will be able to download a copy which can be burnt to disk or request a disk be sent to you, though I cannot remember if they still send free Ubuntu disks out.
Linux typically runs very well on limited resource computers such as the one you are in possession of. Did I mention it was free? If nothing else, you can use it to reformat the harddrive using their Live Boot disk - it allows you to use the Ubuntu operating system without installing it. You boot from the cd and can use their harddrive utility, or install Linux to the harddrive, or just check it out to see how it works.
Dec 14, 2008 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
