Question about Proscan 32LA30Q Television
I can't program a Direct TV remote for Proscan TV
    President:
  • 814 Answers
Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Posted on May 21, 2009
3 Suggested Answers
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Posted on Mar 17, 2009
  • 20 Answers
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Posted on May 30, 2010
Proscan website
Depend on the manufacturer. You may able to install.
Oct 22, 2013 | Televison & Video
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
My remote quit working.
If ur direct tv remote have problems,or it defective.Talk to ur direct tv satalite provider to get another remote.U can try website like 1-800-Remotes factory original.To buy ur Proscan tv original remote.
May 03, 2010 | Proscan 32LB30QD 32 in. LCD TV
Remote control
These remote codes also depend on what the exact make and model of the remote control is that you are using. These remotes can also use 2,3,4 or even 5 digits. The other factor is that some universal remotes will recognise the code for your proscan TV - but others will not depending on how they are programmed.
I will give you the most common 4 digit codes for Proscan and hopefully these work for you. If not please post up further detail on the remote control - exact make and model no. that you are using in order for us to solve the problem.
Common Proscan TV codes:
0000, 0015, 0031, 0107, 0162, 0163,1000, 1008, 1068, 1108, 2010, 2118, 2144, 2205
If this works for you please do rate my answer using the thumbs. If not please provide more detail and I will be happy to respond.
Thanks for using FixYa.
Jan 08, 2010 | Proscan 19LA25Q 19 in. LCD Television
I just installed direct tv and their remote wont let me change volume. if I use the tv remote I lose the programming. Need a code so the tv can be controlled by direct tv's remote.
Hi, post the direct TV remote # and the box model # so I can lookup the info for you. you probably already know directTVs remote programming is built into the menu (codes and all).
You did not mention if the DT remote powers the TV on or off?
post more info if you still need help and I'll try
Thanks
Eric
Sep 04, 2009 | Proscan 42LA45H 42 in. LCD TV
32" proscan dual hd tv can't get universal or direct tv remote to work what now
Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
Craig www.classtorations.com
Jun 08, 2008 | Proscan PS32500 32" TV
Remote Code
evelchuckjr,
I came here looking to find out how to program my direct TV remove without any luck. The codes that direct TV provided are 10047 and 11447 for proscan. What code does dish provide?
Thom
Dec 06, 2007 | Proscan 26LA30Q 26 in. LCD Television
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Proscan 32LA30Q Television Logo
4,760 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
