Question about Samsung SGH-D900 Cellular Phone
Won't turn on
After leaving my phone in the car for one and a half days, it won't turn on.  it shows the battery symbol while charging and now it's done charging, but the display doesn't come up.  is there any hope for my very tight budget?
  • 425 Answers
Since you are in a tight budget now.
if you can open your phone, try checking the connections inside especially in the lcd part. look also for moisture build up.
hope it helps...
Posted on Oct 17, 2007
SOURCE:
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
MY CORDLESS PHONE BATTERY KEEPS DYING
You could try leaving it on charge a bit longer but if it keeps happening it either means dock doesn't charge the battery any longer (check for the charging symbol on the phone when in dock), or the battery in the phone has had its days.
Jun 05, 2012 | Vtech ia5870 Analog Cordless Phone
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
My phone charges but never reaches the stage where message says "your battery is full now", even if i leave it overnight to charge. then when i turn the phone on, it's life is only a couple...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 06, 2011 | Nokia 7230 Cell Phone
My Samung P3 will no longer keep a charge. I can leave it on the charger all day, then turn it on and the display shows a half charge. After which, it will just shut off saying battery not charged. What...
May 08, 2011 | Samsung YP-P3JCB Digital Media Player
Phone regularly cutting out
This is due to malfunction of battery,
i have also experienced same kind of problem with nokia set which is other model. i have also done same what you have done. Change or replace your mobile battery. so it 'll finally solves your problem.
Apr 21, 2008 | Nokia 2310 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
168 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
