Question about Samsung ML 1710 Laser Printer
Where do I find the toner waste hopper - Samsung ML 1710 Laser Printer
    Problem Solver:
  • 9 Answers
Hi, this printer should not have wast hopper at all.
Due our experience for the samsung printer the ML 1710 don't have it.
to refill this toner unscrew 5 top screws then open top cover you will find powder container refill it and re screw screws back.
If it have CHIP you need bought one if this toner done 2000 pages.
But I suggest bought compatible toner, it will helps you reduce messy job, the toner poweder is high risk if you are going to refill in your room it will caused health problem include cancer.
We don't have this toner at the moment currently.
Hope it help.
Posted on May 16, 2009
Why toner spills ?
when toner spills it could be that the seal between toner tray/harper/ hopper is not working properly, it could also be developer inside the drum that is worn down, if you page/print has a slight grey background then replace the developer, you will need a qualified technician for this as there is settings that need to be done after developer replacement
Apr 29, 2014 | Ricoh Aficio MP2352 Copier
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Jul 15, 2013 | Canon Office Equipment & Supplies
The problem is about error 000002 0000 for my ir6000
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Feb 14, 2013 | Canon imageRUNNER 7200 Copier
I have a red streak on the page coming from my HP color laser Juest 2600n
look at the green roller and see if you have shots on the green surface, remember if there is a hit or a line, this will be marked exactly the same on the sheet, and are usually small so as describe reviews all the green cylinder, finger Giral in search of imperfections on all surfaces, if you find them, but here you do not have anything to do, you must replace the entire cartridge cleaning (half of the cartridge in which roll is green) or alternatively, the entire cartridge.
http://www.uninetimaging.com/newsletter/HP_2600_Reman_Eng.pdf
Now, if you do not find that surface damage, open the cartridge (above are instructions on how to do ", to which sections the cartridge into two halves (the waste hopper and toner hopper new) clean with a solplador of air or a vacuum .... rodillito has an emphasis on black that makes the green roller rolling.
It is counter intuitive what I'm saying but if you read the manual while watching the disarmament of the cartridge you'll realize it's true.
NO SIDE SPOTS UNIFORMS
The lateral blotches are produced because the waste hopper is full of waste toner (waste chute is located detráz green roller DRUM) this happens when we have printed enough, the magazine is full and the toner, this roller is not can take, so to clean the hopper can do the following: a) with an air blower introduces air between the roller and the plastic to remove the toner. b) it is best to cut a hole in the center of the housing that protects the wiper blade (above) and proceed to dump all that excess toner out there. is closed again with adhesive tape and ready.!
Mar 29, 2010 | HP Color LaserJet 2600n Printer
Cannon b840,ink cartridege seems half full ,but fax comes through ist page perfect 2nd fuzzy,blank on all following pages
Sounds like the cartridge is empty. Your cartridge has a waste toner hopper that collects excess toner from being deposited on the page. The half full feeling might just be the weight of the waste toner.
Dec 16, 2009 | Canon FAX-B840 Plain Paper Bubblejet
Error code e000020 in ir6000
E020
General condition
General condition
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
When printing full color brochures, after the first copy I get ink smears and shodow imprints all over the next pages. I've tried the clean up smears procedure on the machine but it doesn't help the...
there should be an option for auto cleaning the printer, if you can't find it, look in the manual
use just regular or construction paper, it will most likely take a lot of sheets of paper, so don't use the fancy expensive type
-or- get a repairman to fix it
Aug 13, 2009 | Xerox Phaser 8400 Laser Printer
How do I find the waste toner hopper?
There are 5 screws on top of the cartridge that have to be removed. Then there are 4 release clips (use small screw driver to release). The cover will come off and you can empty the entire cartridge.
May 16, 2009 | Samsung ML 1710 Laser Printer
Dell 1700 laser. refilled toner, getting gray background
Check toner darkness settings using the setup utility.
Oct 18, 2008 | Dell 1700 Laser Printer
Samsung ML 1710 Laser Printer Logo
149 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
