Question about Nespresso D290 Espresso Machine
After descaling le Cube two flashing buttons won't stop so can't
Nespresso le cube, descale keeping two large/small buttons depressed together. Tank empties descaling mis, as it should. After doing this as required I cleaned machine. On refilling and turning on again the two buttons still keep flashing so I cant make any coffe, just drain the tank again. Help!!
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
Posted on Feb 05, 2011
  • 7 more comments
  • nelliebooker Mar 02, 2011
    My machine started to do this just out of the blue! I tried everything in the troubleshooting guide, but nothing worked. I just rang the Nespresso Service Team and went through a bunch of steps with them - but still nothing. They said they would send a courier to fetch the machine but that it would cost $150 to fix it. Decided to check the web just in case I could try something else.
    THANK YOU tish3030 - this did the trick. Just by taking out the tray/container and holding down the lungo button, it all came back to normal!! I had tried this several times but with the tray in place.
    Just saved $150!!
  • p3d40d596 May 15, 2011
    hello.....from London......did it...and working like new
    Thanks
    Pedro
  • luca Dec 28, 2011
    That was the solution even for me! (Luca - Milan).
  • D Hiltz May 19, 2012
    Whew! This great fix seemed to work for me too. Thanks!!
  • jamie_gamble
    jamie_gamble Jun 13, 2012
    I just had the same problem and this solution wasn't working for me but when I called Nespresso they said to wait 60 seconds between actions (like holding down the buttons together for 5 seconds). Once I did this it responded!
  • ruthann230
    ruthann230 Sep 04, 2012
    thanks a million! had the same problem and gotta love internet, and your hint, for help ;-)
  • Christopher Macsurak
    Christopher Macsurak Nov 11, 2013
    Thank you for taking the time to share this tip, it helped me.
  • Griff Lambert
    Griff Lambert Jul 10, 2014
    Great tip - thanks!
  • Steve Boyle
    Steve Boyle May 23, 2017
    Absolute legend! Thanks - I was descaling it with the tray out but the container I was using must have triggered the tray sensor somehow! Cheers :)
    New Friend:
My machine wont work after all these solutions. I threw it against the wall outside and smashed it up. Lights have stopped flashing now.
Posted on Mar 05, 2013
  • Christina Mar 05, 2013
    I forgot to mention that option!
    New Friend:
Just spoke with nespresso bc I had the same issue (on a citiz) and none of these things were working. the machine has overheated. you need to turn your machine off for 20 minutes to let it cool down. after 20 minutes, turn it back on, let it go through the warm up and then you can take it out of descaling mode by pressing the 2 buttons.
Posted on Sep 08, 2013
  • 1 more comment
    For me removing the tray worked, but I will also keep your tip in mind. It goes to show, sometimes its good to sleep on it. (or wait 20 mins).
  • Peter Moreton
    Peter Moreton Dec 27, 2015
    Way to many buttons and combinations in the manual to operate. If someone can build a unit with just Lungo button and function the world would be a better place. Thanks for the simple fix, had the machine ready for the repair shop, now working like new.
  • Mahmoud Darweesh
    Mahmoud Darweesh Jun 27, 2017
    Thanks a lot. Worked. It was overheated
    New Friend:
Hi - I have an Essenza EN95. After descaling the lights kept on flashing (as in warm up mode) After several attempts I called Nespresso for help. They advised turn off the machine, hold both buttons for 3 seconds, turn the machine back on while holding the buttons (two person job unless you have big hands) after about 30 seconds it worked. Who would have thought of pressing buttons when the power is off??? Good luck!
Posted on Feb 07, 2013
    New Friend:
Worked like a charm, cheers.
Posted on May 28, 2015
I have just decaled and rinsed my machine for the first time, now the lights as flashing and wont return to normal. please can someone help(really need a coffee)
Posted on Feb 12, 2011
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
Very slow water flow, barely filling tea cup
It could be a problem with an air bubble or with scale deposits.
It is recommended that you first run a descaling cycle using the proper descaling product. Do not use vinegar as it can damage your machine. Information on descaling can be found here:
http://www.nespresso.com/fileadmin/shared/_img/manuals/Nes_DescalingKit_CBU_internet_081216.pdf
To find more help with your product go to the website below:
http://www.nespresso.com/#/no/en/coffee_machines/selecteur_gamme/machines-le-cube/le-cube-nespresso-auto-d180---110-v-1
Feb 28, 2011 | Nespresso Le Cube
Nespresso clitz's light is keep blinking. I pressed both button but not working, I turned it on and off and make sure wate container is placed correctly.
It sounds like you've put it into descaling mode. Hold down the "large" button for a second or two and water should start coming through. Press the large button again to stop it. Lift the capsule eject handle and put it back down. Then hold down both buttons for about 3 seconds to exit descaling mode.
Dec 10, 2010 | Nespresso Citiz D110
When I hit the Americano button, it comes out like an espresso, not enough water comes through. I've just descaled. How to fix?
The amount of water is programmed by holding in the button. Put your cup below, and press the button. Keep holding until you are happy with the amount of water that came out - and then let go.
Next time you use it, you just need to do the normal short press on the buttom.
(Both the Espresso and the Lungo button can be programmed.)
Jul 31, 2010 | Nespresso Le Cube
Le cube
Run an entire tank of water through the machine to clear out any remaning descaling solution. Once the tank is empty, you can turn off the machine, and it will exit the descaling mode automatically. Leave it off for a minute or two and then turn it back on, and it should run normally. Remember that the power light will blink while it is warming up when you first turn it on.
Nov 01, 2008 | Nespresso Le Cube
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Where can I download the manual?
The manuals are available on the Nespresso website (www.nespresso.com). Click on the "machines" section, and then choose the le cube. Click on the details page (https://secure.nespresso.com/precom/sima/fiche__NESPRESSO_Le_Cube_D185__N_D185_1_us_en.html) and you should see the link for downloading the manual. You can also download the descaling instructions as well.
Aug 06, 2008 | Nespresso Le Cube
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Nespresso D290 Espresso Machine Logo
27,775 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
