Question about Sony Ericsson W850i Cellular Phone
Lights how do i change the light color on the side of the phone? i see no where does it have options to change display or lights?
  • JillC Oct 16, 2007
    well all of the reviews i have read say it is possible and that you can assign a certain light pattern to certain callers.
    Scholar:
  • 193 Answers
There is no option for that in the mobile
Posted on Oct 16, 2007
On the Alcatel a206g, how can I tell when the battery is fully charged? Does the light change color?
When the battery is fully charged the image of a battery
will display on the screen with 4 bars.
link to on line pdf manual
Alcatel A206G User Manual
Jun 02, 2016 | Alcatel Cell Phones
How to turn off backlight on iphone 4
There is no separate "back light" setting like there used to be on some earlier phones.
In the Settings app of your iPhone, there is a section called "Display & Brightness". You can use that to make your phone's display brighter or dimmer, but as you have probably discovered, it dims or brightens both the foreground and the background elements together as one.
You can turn it all the way down, which is very dim and hard to see in normal indoor light conditions, but may be preferable in extreme low light conditions like in a nightclub setting, or in complete darkness.
Why isn't there a separate back light setting?
To fully answer this, I would probably have get into more than you ever wanted to know about displays.
First, there is really no background or foreground on today's smart phone displays. The foreground elements and background elements we see on the iPhone are really a graphic illusion created by lighting individual pixels with different colors. All of these pixels are on the same plane, so nothing is really behind or in front of anything else. It's just artistically drawn to look that way.
Brightness is simply an "intensity" setting applied uniformly across all of the underlying individual pixels within the display matrix, and has no relationship to color. For clarity, let's look at the difference between lightness in colors, versus display brightness:
COLOR LIGHTNESS is a matter of how much WHITE (all the RGB colors summed, for example) is present in a given color. This has nothing to do with display brightness.
DISPLAY BRIGHTNESS is a matter of how much LIGHT INTENSITY is applied uniformly across all pixels in the display matrix.
At zero display brightness, you would not see white any better than black, blue, green, red or any other color. You wouldn't see anything.
Why did you expect to be able to control the back light?
Prior to the smartphone era, the displays on early cell phones and pagers (and lots of other devices that had displays) had a lighted background that contrasted with dark foreground elements.
The background intensity was a separate setting on those devices, but that's because the background was the only thing that had intensity. The foreground elements were solid black LCD (liquid crystal display) segments that were used to form characters and very simple graphics and lines.
Everything we see on today's smartphone displays is dynamically drawn by lighting different pixels with different colors at different times. Individual pixels on a Retina display are nearly microscopic in size--they cannot be separately discerned by the eye.
Imagine a matrix of microscopic light bulbs, each of which can separately change to any of millions of colors and levels of brightness at any time, on command. Just imagine the sheer number and complexity of possible commands to control a Retina display!
Even if Apple wanted to provide a new feature that enabled us to separately control the perceived "back light", it would only be an illusion as well.
Such a feature would require some sort of complex algorithm to determine which pixels are involved in what you perceive as the "foreground" elements at any given time, so it could add intensity only to those pixels considered to be "background" at any given time.
Since "foreground" and "background" elements drastically change shape (and location) at any time, such a feature would be pretty daunting to implement.
You might be better off using a pure black graphic as your background image if your goal is to have more contrast to make the app icons stand out.
Cheers,
-=Cameron
Aug 12, 2014 | Apple iPhone4 4G iPhone 4
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
Casio F91W-1 Wrist Watch- backlight color
You can change the backlight on a casio wristwatch by holding the Light button, but only if it has an LED light in the side of the screen such as yours does. There is Light Blue, Red, Pink, Blue, Green LEDs in the side of the screen and you can change between them. There is also an option that flashes between all the LEDs when you press the button.
May 06, 2010 | Casio F91W-1 Wrist Watch
My nokia 6085 mini display wont light . You can see the time displayed but it is dark.
change the display IC near the main board strip connector, there r two ICs the one on the right side is for mini display , re heat it if it doesn't work after changing the IC ;)
Jun 06, 2009 | Nokia 6085 Cellular Phone
Image quality
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Logitech QuickCam Chat Personal Web Camera
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech web cam
Connection Issues:
Low Light Boost:
Feb 27, 2008 | Logitech Quickcam Chat Webcam
Pic quality
Connection Issues:
Low Light Boost:
Using Latest Software:
Finally, make sure you are using the latest release of Logitech camera software. You can download the latest release from the Logitech Downloads + Parts page.
Feb 26, 2008 | Logitech Webcam
Shows Dark
Connection Issues:
Low Light Boost:
Jan 13, 2008 | Logitech Quickcam Chat Webcam
Sony Ericsson W850i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
