Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
I keep getting a message that the alignment has failed. The printer is not photo paper through smoothly. I have checked for paper jams. I have replaced the cartridge. Also the color is light and not quite right.
It keeps saying print alignment failed
Posted on May 26, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
I cant get the printer to align what should i do
IssueA Printer alignment failed error message displays on the product.SolutionFollow these steps to resolve the issue.
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Touch the Setup icon.
  3. Touch the down arrow button (c01093709.jpg) and select Tools.
  4. Touch the down arrow button (c01093709.jpg) and select Align Printer. The product calibrates, aligns the printhead, and prints an alignment page.
  5. Touch OK to close the message.
  6. Recycle or discard the alignment page.
CauseAn incorrect type of paper is loaded in the input tray. If colored paper or photo paper is loaded in the input tray when aligning the product, the alignment might fail.
Jul 21, 2011 | HP Photosmart D7460 Printer
I installed a new black ink cartgage and printed a alignment page. After alignment was finished I tried to print an envelope through microwsoft word and received a jam message. I have no paper missing on...
in the back of the printer, there is a plastic door try to dismount check if there is some thing triggers the "jam " error put it again and check, if not, try by your hand to put the head on far left side, some jam errors are from lost head position , then check the rolling rod it has plastic finger looks like half-round, if this finger is jammed and it's tip is not smooth with paper flow it will trigger paper jam
this plastic finger might jammed before and strongly removed the jammed paper which might changed it's curvature hopefully it work
Dec 07, 2010 | HP Officejet J5780 All-In-One InkJet...
Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Jan 30, 2010 | Epson STYLUS R350 Photo Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Fax feed jams, accepts single copies only
Check for pieces of paper that could be stuck in the ADF unit. If that doesn't work your ADF rollers are smooth and you should try replacing them.
Jan 15, 2009 | HP Officejet J5780 All-In-One InkJet...
Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
Dec 31, 2007 | Lexmark P450 InkJet Photo Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
470 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
