Question about Kenmore 24 in. 15932 Built-in Dishwasher
I have a KENMORE Model 665 Ultra Wash
The problem is the it is so noisey when washing and rinsing I can  not here myself think!.. It fills fine, washes fine, drains fine and the spin arms work. I did take some of it apart inside and got down to where the grinder thing is and that all seems fine so I am wonder if it the whole motor and how do I access that? Thanks For any help you can give me!
  • 2 more comments
  • Ga bles Dec 12, 2007
    experiencing same problem on same model.
    sounds like a high shrill
  • Anonymous Dec 28, 2007
    We have the same problem. Any help would be appreciated.
  • Anonymous Mar 04, 2008
    makes noise so loud tore apart sounds like motor bad or something stuck in food or water drain is at. took bottom off and can see or hear were noise is but can't stop it any suggestions please. thanks
  • Anonymous Jan 20, 2009
    Kenmore dishwasher, Elite model 665.13439. Purchased in 2007. It just started howling. Otherwise, it functions fine. I presume it's the bearings on the motor. If anyone has another suggestion, I'd be interested in hearing it.
I ended up finding a motor on ebay and replaced it myself. I wasn't too hard of a job and I save a lot on money!
Now it is HEAVEN when I was dishes.. It is like a wisper!!!
Posted on Jan 07, 2008
Run the washer first with nothing in it. see if your still hear the noise. only time it should make any noise is if there is not enough water also rotate the bottom jet and see if it turn s smood.
Posted on Jan 06, 2008
I have a Kenmore ultra wash model 665, stock# 15951. When the tub starts to fill the water runs out the drain.
This means there is either an air gap in the drain hose or the drain hose loop is less than 32" high preventing back flow
Sep 18, 2010 | Kenmore 24 in. 15159 Built-in Dishwasher
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Will not drain
can you see the check valve? may have something blocking it closed.
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
May 20, 2008 | Dishwashers
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Wash cycle not working...
Kerbri, it sounds like your pressure switch could be the culprit. Under the top console the switch will be on the left side. There will be a clear tube that runs from the tub to the switch. Take another piece of tubing about the same size in diameter, disconnect the tube to the pressure switch and connect the tube. Blow into the pressure switch and see if the washer starts agitating. If so, replace the pressure switch.. Another thing to check would be the harness to the motor, make sure it is on tight. Good luck
Jun 26, 2006 | Kenmore 23022 Top Load Washer
Kenmore 24 in. 15932 Built-in Dishwasher Logo
282 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
