Question about Pride Mobility Victory 3 Wheel Electric Scooter
The scooter rar wheels locked up nothing moves
The scooter was running fine then everything locked up freewheel lever won't release it either won't move batteries are charged
  • Pride Master
  • 1,263 Answers
Hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
Posted on Jul 25, 2009
TGA Breeze S4. Why doesn't it freewheel?
hi George, if you took the brake apart , you reassembled that incorrectly as there should be a slight gap when moving the lever into free-wheel to allow the motor to move freely...Normal you put a plate the wrong way during reassembly ...a common mistake...
Now with the free wheel working correctly both wheels will move in the same direction when the brake is released either by powering forward or backwards or using the freewheel lever has released...what you described is a normal action ...because they can move independently...that's by design.. so strip the brake again and make sure plates and springs if fitted are the right way round...
Regards
Mar 01, 2016 | Health & Beauty
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Scooter will not move. Batteries and charger are fine. Controller was replaced. What could cause the problem
Have you checked that the freewheel lever is properly engaged? You will find it somewhere near the rear wheels. If it isn't engaged the scooter will not move when the power levers are pressed. It would react like a car in neutral ie nothing would happen.
Jul 15, 2014 | Pride Mobility Products Revo (3wheel)
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
Celebrity x mobility scooter . error code 5
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
May 27, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Won't move when drive leaver pushed
go to my group page on facebook wac mobility scooter and i will message you.many thanks billy
Mar 19, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Won't move with charged batterys
Hi, any bleeping, flashing lights , double check the freewheel lever,
1. Any clicking from the rear .
Please keep me updated.
Regards
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
In Drive position the wheels are locked and in neutral the wheels remain locked and will not spin or free wheel. In drive with the battery in the unit just clicks but does not move, everything works such...
I would suspect that the brake is not releasing causing your problem. When you place the handle in freewheel and you can't push the scooter easily then the brake pad is stuck on the motor housing. If you are able remove the seat and back cover remove the drive wheel on the side of the scooter nearest the freewheel lever usually the right side. you should be able to see the brake attached to the end of the motor with 3 or 4 hex head screws. take the brake off the end of the motor and carefully leave the wiring attached ( don't break or remove the wires going to the brake or the scooter will not run at all) remove the brake and place or tie it up where it won't fall or drag. Put the drive wheel back on and turn the scooter on and see if it will now move. If it moves like it should you will have to replace the brake. You can drive the scooter like this but remember you do not have brakes so the scooter can roll backwards or forward when not on and especially on ramps Hope this helps
Apr 23, 2011 | Drive Medical Drive Falcon 3 Wheel Compact...
Have a Bolwell mobility scooter with the problem that it will not go. Battery indicator indicates fully charged but left indicator bar on battery display is flashing with a clicking sound near rear wheel...
Hi u mention the brake is off do u mean it's in freewheel if u can push the scooter it's in freewheel .push the lever into drive : when lever is in freewheel the scooter will not move..type in Google search ( bolwell mobility scooter manual ) .cheers
Jul 05, 2017 | Health & Beauty
Pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
Nov 02, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride Mobility Victory 3 Wheel Electric Scooter Logo
585 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
