Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
Blades won't engage
I have an MTD 42 " lawn mower, when I engage the blades it takes a few min to get them moving, as soon as I start cutting, the stop again. I have changed the belts but still have the same problem. Any Idea's???
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
Posted on May 16, 2009
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Mtd engage blades it smokes and make noise
Have you physically moved each blade by hand (with the machine shut-off),spark plug disconnected to see if both or all of the cutting blades move freely if there is any binding you probably have a bad blade spindle bearing . If those move o.k. then you're going to want to check the pulleys on top of the deck, one of these which do not go to the blades may possibly have a bad bearing and is not moving freely causing the belt to be burning up.
Dec 03, 2012 | Garden
I have a 42" mtd lawn tractor. The blades do not
The blades engage via a belt, that goes around a series of pullies, one of those pullies is a tension pulley that is connected to your pto lever by springs, the engine has nothing to do with your blades until after you engage the lever, I would check your belt. It could be loose, and if you engage the blades it could take it a few to get up to speed, thus making it seem like its only when the engine is warm.
Does everything else work fine? As in the tractor moves when the blades are not engaged?
Jul 11, 2012 | Garden
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
680 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
