Problem with Dyson DC07 Bagless Upright Cyclonic Vacuum
Ok heres my problem, I was using it and it started making this horrible loud noise, stopped the hoover and it looked like the brushes were full of dog hair so cut that all away, its still doing it and the brushes are not moving so we thought maybe it was the belt, but the belt looks to be fine. The noise starts when I put the head of the hoover down to hoover, I can use the rest of it fine (less suctions though) I have no manual with this as I bought it second hand so dont know what I can and cant try. Any ideas please??
3,671 people viewed this problem
This solution has been voted best by the Fixya Commnunity
Ensure plug is not in the socket.
remove the guard from around the roller on base of Dyson by turning 3 screws 90 Deg anti clock wise.
unclip belt from the metal spindle from the motor.
Pull out the roller.
Pull the end of the roller out.
They do not screw, they just pull out.
Clean the muck out from inside the roller ends.
Put end caps back on.
put belt on and thread through the slot.
put belt back on to motor spindle.
Ta da it stops squeeling.
The sound is just there to tell you that the brushes are not spinning. Awful huh? lol Well, the problem with Dyson is that they are very difficult for the customers to fix themselves. You can try to reposition the brushroll ends, but without a belt lifter, it's pretty hard to do. I suggest calling Dyson directly @ 312 469-5923.
Marci
This is actually an internal problem. I had this happen a few years ago and had to have it serviced. It was still under warranty so I didn't pay anything.
It has to do with the gears or something similar (sorry I cannot remember exactly what it's called) I called the number on the side of the vacuum and the operator listened to the vacuum and told me the gears (or something) were stripped.
I'm on here looking to see if I can repair it myself.
There could be a few things that would cause your Dyson to have no suction. I will give
you detailed step by step instructions along with pictures on how you can
diagnose this.
Possible Problem
#1. The first problem is extremely common. In fact, we probably see
between 2-3 of these problems every week. It mostly happens after people
take the bottom plate off the vacuum in order to clean the roller brush. What happens
is when they reinstall the bottom plate, they put it on on
incorrectly. It's actually very easy to do. When the bottom plate
(soleplate) is installed wrong, there will be a gap between the bottom plate,
and the agitator housing, or the purple tray the roller brush sits in. This will cause the
soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to
the user that vacuum has lost suction power because without the brushes hitting
the carpet, the machine will not pick up very well on floors, but when they use the
attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in
between the two housings:
Here's another picture, that is the RIGHT way to install
the soleplate:
I would say probably 6 times
out of 10 this is the problem with the customers machine. If you checked the
soleplate and it is installed correctly, move on to the second possible
problem.
Possible Problem # 2. Turn the
vacuum cleaner upside down so the brush roller is facing upwards. I found the
easiest way to work on it is to put it on a counter top or work bench. On the
left hand side behind the roller brush you should see a flexible transparent
hose that goes from the motor to the agitator housing. This hose actually
has a lot of strain on it when the vacuum cleaner is in the reclined position.
When the first few series of Dyson DC07 models came out, they didn't make this
hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually
right where the end of the hose that goes into the agitator housing. Examine your
hose and see if you have any visible cracks in this hose. If you need to you may
just remove the entire hose assembly by pulling on it. It will easily come right
out of the machine so you can inspect it better. Here's a picture of where the hose
usually cracks:
This would
also explain why the vacuum works fine when using the attachments, but not on
the floors. The attachment hose uses a different suction channel, and when the
machine is in the upright position, no suction goes through this hose. If you do
find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part #
904219
Possible Problem #3.
I would suspect that this may not be the problem, but if neither of the
solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added
there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction
port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for
you, try this last one. The Dyson DC07
models use a clutch mechanism that stops the roller brush from spinning when
changed from carpet mode to bare floor mode. This clutch mechanism is a notorious
problem with all Dyson models, in fact they were such a problem that Dyson
had to redesign the DC07 model to a non-clutch system. Even if yours is one of
the newer ones that don't use a clutch, yours still has a belt inside. You can
tell if your model uses a clutch or not by the shape of the roller brush. If
your brush is a perfect cylinder shape, yours does NOT have a clutch. To check
and see if the clutch or the belt have gone bad, first release the handle on the
vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet
mode. Now while the handle has been released, turn the machine upside down and
see if the brushes are spinning. If the brushes are spinning then turn the
vacuum right side up and put the brushes on the floor. Can you still hear the
brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your
brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to
you, please be sure to rate this repair as helpful by clicking the thumbs up
icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Source: dyson dc07 animal\ no suction
The belt is probably worn or stretched. When this happens the belt won't turn
the roller brush when it is against the carpet. Here is a link for the
manual and links for the belt you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Source: Hi my dyson dc07 animal has suction but the brush
The most common problem with this machine is that either the filters are blocked, or you have a blockage in the hose. Check and replace fiters if necessary.
Rob
Source: My Dyson Animal Dc07 is having problems suction problems
I have three dogs and know the hair can clog up the brushes so they don't spin. They seem to move freely when I move...
While using the dyson (pet model) it started to make a loud noise. I looked & discovered the brush bar was full of hair!...
I HAVE A HOOVER POWERMAX II WITH SOFT GUARD. WHEN I TURN ON THE POWER, IT SOUNDS LIKE A MOTOR BIKE. WHAT IS WRONG? IT...
HOOVER U8143-900 UPRIGHT HAS LITTLE SUCTION ALL BRUSHES ROTATE SO I'M SURE THE BELT IS OKAY. DO YOU ANY SUGGESTIONS????
while vacuming carpet (with vacum set on carpet) it suddenly makes a very loud noise. it also doesn't seem to glide...
I have changed the belt on my Dyson DC07 and the suction is now like new, however it is hugely loud to the point of...
So I do not get full suction...when turn over powerhead, remove soleplate, look at area where internal hose connects,...
Guest Hoover is making a terrible loud noise. Have cleaned it completly, It almost sounds likes its taking off. Hoover is not that old so can not be engine. Help its out of guarantee and as mentioned not that old. It happens when I switch it on checked brushes nothing blocking it and as already mentioned took all apart and cleaned. Many Thanks.
Feb 07, 2009
Guest I have the same problem with the noise. I cleaned the roller and it spins and the belt is okay, just the noise sounds like it needs to be lubricated or the motor is not working. Someting weird. Please help.
Jan 01, 2009
Guest Same problem when head is lowered to carpet mode. When it started I found a string wrapped around roller. Took this out, took head cover off and cleaned out junk. Roller goes like crazy but makes a terrible noise.
Dec 06, 2008
Guest yep, i put it down in the carpet vacuum mode and it is ok for a 10 seconds then I get an awful high pitch whining noise. When you move it back to upright it stops. What can be done?
Sep 05, 2008
LindaKien I use my dyson to vacuum up at a restraunt twice a week.
My problem is that it make a HUGE grinding noise when
I drop the head. It stops when I put the head back up; but
when I goto continue to clean it is NOISEYYY again.
I check that the aggitator belt is spinning around and the
canister does not need emptied. I have even gone as far
as to tighten any loose screws underrneath and clean out
any hair/fur wrapped around the aggitator belt. AND greased
the connections that spin underneath.
Whaat else can be making all this horrible wrackett ??!!??
LindaK
lawless.rip@gmail.com
Apr 23, 2008
Guest Dyson DC17 Animal Hair Vacuum is making a horrible noise when head is positioned down to clean carpet. Remove threads from brushes but it still makes noise. cat
Mar 30, 2008
