Question about Freezers
Fridge/freezer gets cold, but won't stay cold.
Our Fridge Freezer stops working once it has reached the correct temperature. The internal lights work, but it will not begin cooling again unless it is turned off at the wall briefly and then turned back on.
It has a digital thermostat with 5 lights at the top, but adjusting the setting on this doesn't seem to help.
Is this likely to be something I can fix?
  • chemics Nov 13, 2007
    Appliance completely stopped working in the end, so I bought a new one.
  • Anonymous Mar 19, 2014
    The fridge unit is not cooling. It's at room temperature. There's a red light. The freezer unit is warmer than it should be. Any ideas on how to fix?
  • 72 Answers
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
What does the red warning light by the triangle mean on a blomberg
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Whirlpool fridge freezer
Totally a normal action.. When the compressor switches off once the temperature is reached, or possibly after a defrost cycle, if the gas hasn't quite equalised, it will click once or twice then start up.If the compressor has a starting capacitor and it does the clicking, then one needs to check the capacitor.
Sep 22, 2013 | Freezers
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Hi,Ihave had my electrolux fridge freezer for two years now and it is sited in my garage.When it gets really cold the freezer turns off defrosting everything,just found out if it drops below 10 degrees it...
Good day,
Not really. Domestic refrigerators are designed to operate in an environment where people live.
Most all manufacturers recommend that they not be placed in an area that goes below 55 degrees.
At any temperature below that it starts to degrade.
Cold enough and it will not work at all.
The reason is once the fresh food compartment reaches it's normal temperature of 33-37 degrees, it shuts the whole machine off.
That is by design, on any refrigerator like yours that has only one compressor and cooling fan motor.
As well, there are other issues. In that situation, the machine could well stay off 12 to even 24 hours.
The compressor has an oil sump in it, and the oil becomes very thick. When it finally tries to start, it creates a very stressful situation for the compressor, and could substantialy reduce it's life.
Jan 17, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 | Freezers
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 | Freezers
Freezers Logo
469 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
