Question about Kodak EASYSHARE M1063 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
I dropped my kodak m1063 easyshare camera whiel takign a picture the lens was extended when dropped. One side of the lens is not crooked inwardly and stuck, it also does not stay on when the power button is pushed, it automatically closes the reason being the lens is stuck; when turning the camera off (before it was dropped) the lens automatically retracts. I need an estimate to how much this will cost to get repaired.
  • cutie4realie May 16, 2009
    ........set it how & wouldn't this damage the pins or break something?
    Also when i shake it, it sounds like something really tiny bouncing around in a small space
  • Favorite1ne May 20, 2009
    "The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed"
  • 52 Answers
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
Posted on May 16, 2009
Kodak m1063 lens stuck closed won't open
I suggest you take your camera to a digital/Kodak camera repairer.
Apr 18, 2013 | Kodak EasyShare V1003 Digital Camera
Kodak easyshare c1530 won't turn on after slighty dropped
Hello Doris, You can "GENTLY" try to push the lens slowly back into the camera with the palm of your hand, note I said gently and slowly, do not use force !!! Then turn on camera and see if this helped, if not it is repair time.
Jan 26, 2013 | Kodak C1530 Digital Camera
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
My camera wont turn on and lens stays out
are you using the battery that came from the box KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001
first charged the battery for 4hrs and make sure when you charge it theres a light indicator in the camera., you may also try to turn On the camera while its charging in a AC adaptor., If its did the same thing call kodak toll free 1 800 235 6325. it means the camera gear lens is already defective thats why your camera will not stay On
Oct 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Kodak easy share M1063 digital camera wont stay on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
Won't turn on
Keep holding the power up button on untill it oppens up the lens I mean and light up the disoplay.
I hope you did not dropped it to a hard surface.
Vitally
May 28, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak M1063 Camera will not stay on.
You are getting a lens error it is not fully booting up causing your issue.
May 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
KODAK M863 LENS STUCK
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Apr 18, 2009 | Kodak EasyShare M863 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
1,618 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
