Question about Kenmore 22422 Top Load Washer
Hot water run all time when washing
Hot water keep run when wahing
  • 15,935 Answers
The water valve has failed.
If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you’ve attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any “Do-It-Yourselfer” can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Mar 15, 2011 | LG Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Mold on the rubber seal of bosch washing machine
RUN A LOAD OF HOT WATER WITH 1 QUART OF WHITE VINEGAR, THAT WILL KILL THE MOLD, THEN WIP IT OFF THE SEAL
Aug 24, 2009 | LG WM-2277HW Front Load Washer
Cold water knob is not working
Check the screen on the cold valve. If power is getting to the valve and the screens are clean then the coil is bad. Check continuity if you have a meter.
eric
Jul 01, 2009 | Washing Machines
FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Mar 30, 2009 | Fisher Paykel EcoSmart GWL15
WFK 2401
Replace hot water valve.
Aug 13, 2008 | Bosch WFK 2401
Water supply
yes it is normal. It fills up during the washing proces
I had the same thought at first but it truns out ok.
Jun 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener compartment filling up with water and staying there after each wash. have taken bottom part of wahing machine off and opened the dial to let excess water and other stuff out. many thanks
im guessing its a top load.
usually that water is from detergent that got down it and harden clogging line
sometimes its just spill over water from another compartment, as long as your fabric softner is dispensing you are fine
if you acutally want to fix it you have to take off the drawer and clean tubing, some use wire hangers, and pour hot water down line, but this can rip line.
but alot of time this water is normal from spill over
May 02, 2008 | Washing Machines
Roper washing machine hot water won't shut off
An obstruction in the hot water-inlet valve may mean that it's no longer able to shut off and should be replaced. Good luck !
Sep 11, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
