Can not reassemble my waher after replacing the gearbox/cuppling
I have taken my Kenmore 70 series washer apart to replace the gearbox/cupling part. I can not make the three long bolt housings meet the base in order to reassemble.
    President:
  • 1,136 Answers
Hi, you talking about the bolts for the trasmission? You need to make sure the spin basket drive is pushed up into the brake housing far enough. Using the white lever on the basket drive, push up on it and turn it clockwise. It will be heavy but, it will ush up. Now you should be able to push the transmission up tight enough to put bolts in. If I can help further, please let me knwo
THanks
Vic
Posted on May 16, 2009
Kenmore 70 series will not spin all the water out of the clothes
there is a fault with your spin cycle speed this is normally an internal gearbox fault
Jan 02, 2011 | Kenmore 24932 Top Load Washer
your lid switch is bad.you can take a pen and push it up and down to hear if it clicks.you may want to take it off and see if it has split.very easy to do.if you need help i can walk you thru it.
Mar 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series is slow to spin
it sounds like you have a bad clutch in the washer. To diagnose this failure, you would need to pull off the washer cabinet and pull the transmission. It is likely that you would find the clutch band glazed over. It is probably not exerting enough torque to release the brake and spin the washer.If you find this problem, you can try sanding the band to rough it up. Reassemble the washer and check for proper spin. If this fixes the problem, you will need to order and replace the clutch band.
This type of procedure is usually performed by a service technician. I don't recommend attempting this repair unless you are completely confident that you can safely perform the work.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Abnormal shaking during spin cycle
THIS IS CALLED A BEARING JOB THE INNER TUB AND THE OUTER TUB HAS TO BE REPLACED THESE PART ARE USALLY UNDER THE MAN. WARRANT BUT THE LABOR IS PRETTY EXPENSIVE ON THIS JOB BECAUSE THE WHOLE WAHER HAS TO BE TAKEN APART
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Won't agitate or spin
Probably the motor coupling has cracked. Located between the motor and transmission/gearbox.
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series model 100.xxxxxxx
Forget about the belt and replace the coupler first. if that doesnt fully fix it then replace the clutch. But just changing the drive coupler should fix it up good as new.
Nov 15, 2008 | Kenmore 24032\24036 Top Load Washer
Does it hum or click? If it clicks your coupler is out or a hum could be a faulted gearcase.
Aug 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washer 70 Series shakes badly during spin after repairs
make sure that the 3 corner triangel thats betwwn the tub support and the base is in the right position all 3 parts corners should be pointing the same way
Mar 03, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
