Exterior Fan not starting.
The interior unit comes on normally, but the exterior unit - compressor starts - fan does not. Fuses check OK - compressor stops in short time. Fan never starts, just a hum, and hot to touch. Could the fan be the problem, or starter relay??? Help please.
  • 3,267 Answers
Its the problem with the fan. !1 or more coils have burnt out and if repaired will have to rewind the shorted coil/armature. Better to replace the fan. Also when getting it repaired ask them to check the thermostat too...............sodeep
Posted on May 16, 2009
Is there a reset button on a FASCO D9709 AC unit?
Hello, the fan in the interior unit takes a few minutes to start in heating mode.
If you are talking of the fan in the exterior unit, then that fan is stuck or burned.
If you try to use in cold mode and the fan of the interior unit dont run, then you have problems in the electronic board.
Sep 15, 2014 | Heating & Cooling
Temperature gauge goes up down
that is a strange one , i think the problem is with the exterior temp sender as the fan cutting in and temp gauge falling is what you'd expect ,try diconnecting the exterior temp gauge ,may be a fuse for it ,if that is all ok i'd get the ECU checked as may be getting a short let me know how it goes
Apr 21, 2014 | Ford Freestar Cars & Trucks
Interior lights and exterior lights are dim, along with heater fan running slow, when first starting car. After a few seconds, lights brighten and fan speeds up. What is it?
For some reason the alternator output is very low when the lights are dim. Something happens to bring output up to normal when they get bright.
Slipping belt, or an electrical problem.
Jan 27, 2013 | 1996 Pontiac Grand Am
I have a trane XB1000 unit (DOB around 2000). Was cooling fine, but noted a whining noise at the outside unit. Loudest near the base below compressor tank. Interior filter clean, a-coil fairly clean,...
If the sound is coming from the outdoor unit, check fan blade if unbalance and if the compressor is making the noise, an internal mounting spring must be broken, be ready to replace the compressor when the internal pipe got broken.
Sep 03, 2011 | Heating & Cooling
Motor and fan on exterior unit work once then do
im not qiute sure about this but it sounds to me like you are getting a hard lockout from high or low pressuers on the out side unit
Aug 27, 2009 | Heating & Cooling
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
