Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Bar oiler not working
Oiler not working on husqvarna 455 rancher, just cleaned it, so it's not from debris. What else can I try before I take it to the dealer?
  • brownbear399 May 22, 2009
    no oil getting to bar, I also have another saw that chain cuts fine then stops cutting but still goes around bar but then seems to catch then starts cutting agian.why?????
  • 143 Answers
The chain oil pump must be worn. The pump is fitted behiend the clutch and chain drive.Remove this by turning clockwise.
Posted on May 17, 2009
Make sure the oil tank vent opening is not blocked with debris. When you take the bar off there is a shiny metal plate held by one screw that you need to remove to get to the oil pump. Under this plate you will find a small copper screen. This is the vent and when it gets plugged you get a vacuum in the tank and the oil will not flow. I used carb cleaner on mine and it fixed my oil problem.
Posted on May 21, 2012
Youtube
first inspect the worm drive gear that makes the oiler work. this is located behind the clutch and drum. also inspect the bar oiler holes for blockage.
Jul 27, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher, chain getting too loose to tighten after one days use age. Bar oil topped off with every fill up of gas. Bar cleaned in the groove, etc. New chain. The bar will no longer adjust to...
indicates incorrect length chain in use
the adjustment slots should be about 1/3 when fitted moving close to 1/2 when adjusted
the correct adjustment is when the chain in the center of the bar is lifted up the bottom segments of the chain are still in the bar groove
make sure that the oiler hole is not blocked from saw dust and chips
Aug 08, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
How to adjust automatic oiler on 455 husqvarna
I'm sorry, but I'm not aware of any adjustments that can be made to the oiler. Just make sure the ports are clean so that the oiler doesn't get clogged and that the oil lines are all clear and you should be good.
Nov 13, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 Rancher - oil coming out of muffler and not oiler. Just emptied gas and remixed new batch so that should not be issue. It was working fine until I took off chain cover to clean and got brake...
Re-clean the engine case and loose parts. Start the engine with the bar removed--oil should ooze out of the side port where the bar fits to, but nowhere else. Clean the bar drive end oil passages--especially the two small channels that go out to the chain groove on both sides. If you seem to be pumping excess oil out, there should be an oil volume adjustment screw either in the back case or just underneath the case near the lower run of chain. Turn the screw CW to lessen the volume of oil. Hope this helps!
Jun 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Adjusting automatic oiler. Chain is over-heating not getting enough oil. 455 Rancher
check for blockage in feeder pipe, try draining oil tank and clean with fine grade oil or wash out using engine clean by wynns. hope this helps
Jun 30, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 Rancher got it slightly used. It had oiler issues when I got it took it to the shop they installed a new one 3 months later the oiler isn't working,any fix for this?
the rancher uses a plastic oiler gear to a metal gear.the plastic gear always looses in the battle.pull the clutch off and clutch drum.under the drum you will find the plastic gear.replace it and all should be well again
Feb 21, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
2,346 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
