Question about Karcher PSI Electric Pressure Washer
I can't connect the garden hose to the water inlet. I am using a size 5/8'' hose but it wont connect to the unit. Please help!
    President:
  • 389 Answers
Karcher electric pressure washers typically are supplied fitted with the male half of a standard Hozelock connector. You need the female half secured to the end of your hose, and then they just click together.
Posted on May 16, 2009
What does "EFO" stand for? It keeps blinking on my washer
EF0
displays due to washer over-sudsing or due to washer not filling with
Hot
water.
Causes for washer over-sudsing
Not using High Efficiency (HE) detergent.
Too much detergent was added.
Using too much 2X or 3X HE detergent
Solutions for over-sudsing
Always use HE detergent in an HE washer. It is formulated to be a low-sudsing detergent and made especially for HE washers.
Be sure to use the correct amount of detergent. HE washers require only a small amount of detergent.
Note
: This amount may need to be adjusted for water hardness, load size, and soil level.
If using a 2X or 3X concentrated HE detergent, much less detergent is needed. If suds are seen, reduce the amount used.
If using a water softener, less detergent.
Solutions for Hot water not entering the machine are
Make sure both Hot to Cold water hoses are connected properly at the faucets and at the washer.
Fill hoses are usually color coded, blue for cold and red for hot.
Verify that the hot water inlet hose is connected to the hot water faucet.
Verify that the cold water inlet hose is connected to the cold water faucet.
Verify that the hot water inlet hose is connected to the back of the washer into the hot water inlet port.
The inlet port is usually labeled with (H) or (HOT).
Verify that the cold water inlet hose is connected to the back of the washer into the cold water inlet port. This inlet port is usually labeled with (C) or(COLD).
hope this was some help,all the best.
Dec 16, 2016 | Washing Machines
I have a Samsung dehumidifier model HD4080A I'd like to get a drain tube. Do you know of the kind/size I need? If so, please provide. Thank you.
Generally, all that is needed is a section of garden hose, no longer than 5 feet.. The female connection of the garden hose attaches to the male drain hose connection on the unit. A water hose for a washing machine will work,
Hope this helped you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
The hose connection nipple is smaller than the garden hose-connector and leakes. Do I need a special hose or will putting plumbers tape on the nipple stop the leak?
No, that would probably leak too. What you need to do, is go to your local hardware store or home center (Plumbing Dept) and purchase a female to male connector. The female end is to connect to the unit's male hose connection and the other (Male) end, needs to be the same size for garden hose connection. Make sure that you use an appropriately sized washer for the Female end.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Danby DDR5009REE Dehumidifier
Hooked up garden hose for continuous mode but it Problem with the Whirlpool AD35USS Dehumidifier Hooked up garden hose for continuous mode but it seems the water is going into the bucket and not through...
First, the hose should not exceed 5 feet in length. There is no pump in that model dehumidifier. It relies totally on gravity to drain through the hose.
If all of the above is as stated above, I suspect that hose or the tubing inside the hose connecting is clogged. Which forces the water into the bucket rather than the hose.
To remove the clog in the unit, you will need an 18" long plastic Zip Tie or something similar, that is appropriately sized to fit into the hose connection/drain hole. NO wire coat hangers though.
Carefully feed the Zip Tie in to the hose connection. About 6" in the tubing will bend. You need to gingerly work the Zip Tie past this bend, until the Zip Tie bottoms out or you run out of Zip Tie to work with. The slowly remove the Zip Tie while rotating it. This will breakup clog. As you near the end of the Zip Tie coming out, be prepared for some water to follow. DO NOT perform any of this while the unit is plugged in to the wall outlet.
Hope this helped you solve the problem, Robert. Please let me know. Thanks.
May 28, 2011 | Whirlpool AD35USS Dehumidifier
Wont finish FH appears can you tell me the reason why
From the tech sheets on this model, here's what FH means:
If there is no water in the unit:
—Make sure that both valves at the water source(s) are turned
on all the way.
—Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
—Verify inlet valve operation.
■ If there is water in the unit:
—Verify drain pump operation.
—Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
May 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
What pump should be used to flush the Rinnai Continuum 2532 water heater?
any utility pump with garden hose connections or a sump pump set up with hose connections. Allow the unit to flush for at least 45min and be sure to clean the inlet screen when done.
Mar 17, 2010 | Water Heaters
I need to reinstall awater inlet valve on my
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com go here,put your model number in and hopefully this will help you,next time you need help send the model number,good luck,just take off one line at a time and install it into the new valve,the lines are different sizes and the solenoids are colored so it's kind of hard to do this wrong,also there should be instructions with the vavle
Jan 10, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Water leak where hose meets refrigerator connector
I had a similar problem several years ago with water leaking on the floor at behind the fridge. Turned out to be the gasket at a connection the same size as a garden hose at the water valve, so I used a garden hose washer and that did the trick. That was on a Whirlpool vintage about 1990. Can't say what the model was.
Mar 01, 2008 | Refrigerators
Karcher PSI Electric Pressure Washer Logo
477 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
