Question about GE JVM1631 Microwave Oven
I need to replace the magnetron tube
How to replace magnetron tube in GE jvm1631wb003?
  • sarveshvaity May 16, 2009
    Thanks
    Can i replace the magnetron from my microwave with a magnetron from a different microwave with a different part number or does it have to be the same part number?
  • 180 Answers
Remove the connectors and unscrew the mounting screws pull out the defective unit and put a new one.
Posted on May 16, 2009
My GE model JVM1631WB002 is giving off a burning smell. What can I do?
A burning smell is usually a sign of a bad magnetron tube, the microwave source. As they age they take more power, and this causes excess heating that can cause the smell. Eventually the tube burns out and you get no heating. If you've been noticing longer than normal cooking times, it's due to the weak tube.
You can replace a magnetron, but it's a costly part (around $100-$125) and the repair should be done by a professional because of safety concerns. (Several websites describe how to replace a magnetron if you'd like to try it yourself, but you need to be very careful. MICROWAVES USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU.) Between the part and labor costs, when the magnetron goes bad it's often more economical to spend a little more and replace the oven.
There are some other parts that can get hot and sometimes smell, but the magnetron is most common. If you want to keep the oven, I'd suggest letting a professional check it over and give you an estimated for the repair. Then you can decide what you want to do.
Jun 06, 2011 | GE JVM1631 Microwave Oven
Evry thing works except the food is not heated. It makes the noise, timer counts down..
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side of the blower housing, or magnetron tube assembly)))
Dec 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My ge microwave spacemaker 1800 won't heat my food pls help
(((The fuse is located inside the unit along side the magnetron, near the blower housing.)))
Nov 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker 1800 microwave looks and sounds as if it's heating, but no heat is generated when turned on. Is it repairable, and if so, how?
(((The fuse is located inside the unit along side the magnetron)))
Sep 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE PURCHASED 2006 RUNS BUT NO HEAT MICRO/CONV MODEL JEB1095BB
Sep 10, 2009 | GE JVM1630 Microwave Oven
Microwave does not heat
Sounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Jun 23, 2009 | GE JVM1660 Microwave Oven
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 Microwave Suddenly Stops
Tami,
It isn't really difficult to replace... It's the 4000 Volts that go to it and the stored energy (voltage) in the high voltage capacitor that concerns me as far as telling you that it is a do it yourself repair. Also, and this a huge concern, is that after the magnetron tube is replaced, the microwave should be leak checked. A microwave leak detector that is certified is around $400. Now that I said that, I have rarely ever had one that leaked, but it is the law and that's the main reason that it needs to be done. I highly recommend calling GE Factory Service 1-800-432-2737 (1-800-GE Cares) to install the magnetron tube.
Brian
Jan 15, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave GE SpacemakerXL JVM 1450
If you need to ask how to do this task, you may have no idea of the extremely high voltages that exist under the cover, even when unplugged. I would advise a competent person changes it for you.
Aug 26, 2017 | Microwave Ovens
Magnetron tube
Short of buying the service manual, you can find helpful exploded view diagrams by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Replacing the magnetron will require the removal of a lot of screws. Keep track of where they all go.
We have critical safety information at our site, and our link is at our listing here on FixYa.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | GE JVM1440 Microwave Oven
GE JVM1631 Microwave Oven Logo
220 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
