Question about Kenmore Washing Machines
I need an owners manual for Kenmore top load washing machine
  • blueextc3221
    blueextc3221 May 11, 2010
    please provide us with the exact model # ie. 110.987645
  • 20 Answers
Check SEARS.com under parts section most manuals are free on line
Posted on May 22, 2009
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
  • 20 Answers
SOURCE: need manual
yes if you go to the "parts" section of SEARS.com and do a little search and if you have the FULL model # (some thing like xxx.xxxxxxxx) it usually on inside edge of cabinet if the door is open. they have most manuals downloadable
SOURCE: Top loading kenmore washing machine frozen water loaded
Could it be that it has overheated? My mom's washing machine isn't a kenmore, but it has a mechanism that causes it to stall when it is overheated from constant use. After about 15 minutes it cools off and starts again.
Posted on Aug 07, 2009
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
  • 1937 Answers
SOURCE: need schematic for kenmore lid switch top loading
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Posted on Jan 09, 2010
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
I need a manual for a kenmore top load washing machine, model# 110-1594401, serial #CR 3410393, type 111, could u please email me a manual. or trouble shooting information
Go to kenmore.com support for manuals. It will take you a manual site for download. Toward the bottom of the page is a link to trouble shoot top load washers, click that and a download from Sears will start. Hope that helps..
Jul 15, 2011 | Kenmore Washing Machines
I want to be able to read the Owner's/Instruction Manual for Kenmore Elite HE41 Front loading washing machine on line. Where?
Go to managemylife.com and enter your complete MODEL NUMBER (located on a nameplate around the door opening) under their "Manuals" link at the top of the page. The owner's manual and installation manual should be available in .pdf format and can be downloaded or printed for FREE. I hope this helps you.
Apr 18, 2011 | Kenmore Washing Machines
Kenmore top loading washer Direct Drive Model # 11020922990 i need a manual
If you need an owner's manual, you can obtain a replacement copy at managemylife.com. Just type in your model number under their "Manuals" drop down menu and your manual will be listed in .pdf (Adobe) format that you can download or print for FREE.
If you need a repair manual, repairclinic.com has one available that you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Jun 28, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore White 2.1 cu. ft. Compact Portable Top-Load Washing Machine (4472) and i forgot how to use it its been put away for more then 2 years.. can anyone help.
For the best results, you need to refer to your owner's manual for accurate details on how to use all the features of your washer. If you no longer have an owner's manual, you can obtain a FREE copy here:
http://www.managemylife.com/mmh/owner_manuals/17820/KENMORE-Residential-Washers-L0411083?brand_name_search=4472
This was the model I was able to find, based on the information you provided. If this is not the correct manual, please post back with a complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid). If you need further assistance please let me know. I hope you find this information helpful.
Jun 27, 2010 | Washing Machines
Our washing machine kenmore elite stops spinning and does back to washing mode again. there is something that appears 5d during spinning then goes back to washing mode again. thank you
"5d" is actually, "Sd." It means "Suds." If you pop the top on the washer (there should be some tabs along the front were the top joins it. Take a flashlight and check it out. Use a thin screwdriver, pop the tabs, and lift the top up. Once you pop its top, look inside the front panel. There should be a service manual there unless someone has removed it.) Once you get your service manual, you can join the rest of us Kenmore Elite owners in Kenmore Elite H*ll. If this is the Oasis machine, even though you paid a truck load of money for it, it's a piece of junk. The service manual is the most confusing waste of paper I've ever seen. Odds are, you need to replace either the top computer module (they're defective and were recalled) or the RPS. Check eBay for the best prices on these items. If you believe it's your computer module, call Sears--talk nice--and maybe they'll still honor the recall, which has expired. Once you get it fixed, sell it and get something less computerized because the next thing that will go out is your stator. This is the most cheaply built piece of junk washer I have ever owned. Once you look inside it, you'll see what I mean.
Nov 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Drain pump for Kenmore Elite top loading washing mechine
This will not be in the owner's manual.
If you search inside the cavity of your washer, however, you will find the service manual taped to the wall in a plastic bag.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Looking for a Kenmore washer manual
The following link explains step-by-step how to replace the lid switch on a Kenmore Top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple repair. If you have any questions, or need additional assistance, please let me know.
Apr 03, 2009 | Kenmore 24032\24036 Top Load Washer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Washing Machines Logo
144 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
