Question about HP LaserJet 4250n Printer
Replacing a power supply board
Does anyone have instruction on removing and replacing the power supply board on a hp 4250.
I have a service manual for a HP 4200 but the power supply board is different on the 4250.
  • HP Master
  • 691 Answers
Re: replacing a power supply board
The power supply assembly is quite a thing to get out. You really will need a service manual for the 4250.
Go to and see if they have one listed. If not, ask them to get it for you. They can usually find them within a few hours.
You will need to remove the following assemblies just to be able to start removing the PSU:
● Rear output bin
● Rear accessory cover and tray 2 extension door.
● Top, right-side, and left-side covers
● Fuser
● Formatter assembly
Then remove the PCA guide and the part above it
Remove the power switch arm
Disconnect the PSU cables from the DC controller
Remove the fan cover plate
Disconnect the fan and thermistor connectors
Pull the PSU cable through the frame and you are about there. A bit of wriggling and wrangling and the whole assy should come out.
Posted on Oct 16, 2007
0 characters
3 Points
HP P3015 reset maintenance kit count
  1. Power off the printer.
  2. Power on the printer while depressing both the Go and Cancelbuttons. Keep the buttons depressed. The lights will begin to flash in sequence.
  3. Release the buttons when all three lights begin to flash in unison
May 29, 2013 | HP Laserjet P3015X Printer
Hp laserjet 4250 error 58.20
1 Turn the printer off and then on.
2 Reconnect the connector between the air-temperature sensor (the bar mounted across the main cooling fan
on the left side of the printer) and the power supply.
3 Replace the air-temperature sensor.
4 Replace the power-supply assembly.
Oct 16, 2012 | HP LaserJet 4250dtn Printer
Need service manual for hp laserjet 4250
You can download a free copy of the manual for your printer on their website located at Click on customers service and then downloads and enter the make and model of your printer then follow the instructions to download and save a copy to your pc.
Jul 18, 2011 | HP Printers & Copiers
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
May 11, 2010 | Printers & Copiers
My 1050c plotter has come up with error code 0B00D 0000002 can anyone advise on this
This is a Power On Self Test (POST) error. It indicates a missing 24VDC. The probable cause is an over current condition from a motor (24 volts is used to drive motors). The power supply has circuitry that shuts it down in over current conditions to protect itself. There is probably a bind in a mechanical mechanism causing extra stress and over current in one of the motors. The motors are: carriage belt drive, paper drive, and service station motor. Remove the covers and move each mechanism manually to check for binds or broken parts. If nothing is found, replacing the motors is the next best bet. Replace them in this order: Carriage motor, Paper motor, Service station. If that does not cure the problem, replace the Power Supply and finally the Formatter Board. The manual can be downloaded from: and parts can be purchased at:
Sep 07, 2009 | HP DesignJet 1050c plus InkJet Printer
HP 4250 laserjet will not go through the start up sequence.
Well first do what joe said about checking the Plug on the Display, <Here's another solution did you also check the cables( Power Cables going to the format bd ? Sometimes you can bent those pins easily, I have seen it and ok I done it once on HP 4 plus when i first started out as a tech ? Check that ? May I asked What was the reason for replacing the Formatter board in the first Place ? were you getting an error ?
Mar 19, 2009 | HP LaserJet 4250n Printer
Install a Swing plate assembly on hp 4250
Are you sure that is the right part #. Hp has a part # RM1-0043 for a swing plate assembly. If you have one white gear and one black gear you should be ok. I STRONGLY recommend a service technician if your not technically incline.
To replace the swing plate assembly you will first have to remove ALL COVERS top , left, right, front, back. then black paper guide behind fuser, then fuser. next remove main control board and black fan connector and plate. on the otherside(left cover side) of the main board. To make this simple you will have to remove the power supply which sits under your toner cartridge. Good luck
Mar 18, 2009 | HP LaserJet 4250 Printer
Resurrecting dead Fargo 4250
it sounds like you have a bad main board again. you might be having some power issues.
we are an ASC for Fargo, if you need parts send me an email. Although the 4250 has been discontinued a long time ago, parts are scarce.
Aug 16, 2008 | Fargo 4250 Thermal Printer
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
184 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
