Question about Whirlpool ET0WSRXML Top Freezer Refrigerator
Whirlpool ET0MSRXTL00 top freezer that no longer stays cold
I have a whirlpool ET0MSRXTL00 top freezer that no longer stays cold and it is close to a year old. What can i do to solve this problem?
  • SANDOVILLE May 16, 2009
    There is no frost build up, and is that the fan behind the cover in the freezer if so it is running
    President:
  • 1,136 Answers
Hi, Is there a frost buid up or is the evaporator fan motor running? Let me know andI can help you further.
Vic
Posted on May 16, 2009
  • Victor
    Victor May 16, 2009
    You can remove that rear cover and check to see if the evaporator has any frost on it at all. If there is only part of the evaporator with frost on it, you might have a compressor problem. The compressor might have a one year warrenty.
WHIRLPOOL REFRIGERATOR FREEZER ON TOP FREEZER NOT STAYING COLD
there is a timer on the base that takes it thru a defrost mode, Turn it clockwise until it clicks then it will cycle in 30 minutes , do this about twice - it should clear the ice blocking the coil and get colder.
Dec 13, 2013 | Whirlpool Refrigerators
Whirlpool freezer on top is cold but not freezing everything in freezer. i want to reset the unit but i don't know where the rest switch is. how do i find it or what can i do.
open ref. door look up two knobs one numbers one letters.. set the number higher makes comp. run longer and should freeze everything. the letters is a vent the higher the letter more cold air stays in freezer. ok
Feb 13, 2011 | Whirlpool GS5SHAXN Side by Side...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
Whirlpool bottom freezer 5 years old everything freezes in the fridge
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool fridge and freezer 5 years old, won't stay cold enough
Brush are vac coil in back of fridge, take everything out of freezer and clean inside make sure any drain lines in freezer and bottom of fridge are unobstructed, a small piece of wire ran in and out of these tubes will unstop them. This fixed my fridge.
Good luck
Aug 16, 2009 | Whirlpool Refrigerators
My freezer is okay but my refrigerator is not cold really.
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
I have a 10 year old side by side refrigerator. Model No. ED20TKXDN01., Ser. SG0437491. The freezer portion works fine, plenty of cold air. The refrigerator portion is not staying cold, food is spoiling....
take back panel off inside freezer and check if there is ice build up. if so, melt off with a hair dryer and see if it works then. get back to me if you want
Aug 21, 2008 | Whirlpool Refrigerators
Whirlpool ET0WSRXML Top Freezer Refrigerator Logo
184 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
