Question about Toshiba Satellite A105-S4164 Notebook
Laptop won't boot CD with HDD installed.
Toshiba A105-S4164. Replaced the HDD and now it won't boot from the recovery CD. It says it is verifying the hardware and then never does anything more. The CD quits spinning and the laptop sits with a blank screen. If I remove the HDD then it will boot the CD as far as possible without it, goes as far as trying to create a partition then fails (which makes cents). Did I get a bad HDD? I went from an 80Gb to a 120Gb WD1200bevs. Any ideas? Thanks
  • Frank Zhang
    Frank Zhang May 11, 2010
    whats brand model our 80G HDD? what could check out by bios when install 120 HDD?
  • Toshiba Master
  • 2,404 Answers
If it hangs with the new hard drive installed and doesn't without it hooked up then definitely the new hard drive is bad. Return it and get another one.
Posted on May 16, 2009
Start up my toshiba satellite A105 goes to Please Enter-Built-in HDD User Password. I've never put in a password
restart the computer HOLD the key FN +f1 or f2 depend or your model and goes to BIOS setupu and reset the password or disable.
God bless you
Dec 13, 2013 | Toshiba Satellite A105-S4164 Notebook
I have a Toshiba satellite A105-S4164. Suddenly it only types numbers. Mostly a sequence of 1234567890123 etc. I must have turned on some type num lock. How do I turn it off?
To turn off the number lock on a Toshiba laptop -
Press and hold down the Fn key and then press F11 function key - also the LED that indicates the number lock has been enable will then switch off.
Jun 23, 2011 | Toshiba Satellite A105-S4164 Notebook
Recovery Issues A105-s361. Boot sequence always starts with HDD. Tried F12, tried F2 (bios). Any other way to boot from recovery disk(CD-ROM)!!
There is still a way for you to boot from your CD ROM. Just access or go to BIOS again, look for "BOOT" tab and then set the boot sequence of your computer and the set the first priority to be on the (ODD or CD DVD ROM), just make sure you put the CD ROM option at the first section and to do that, Use the arrow keys on your keyboard and highlight it and then press normally "F5 and F6" further instruction are there any way. Once your done, press F10 and select save and exit, Insert the disc on the CD ROM restart your computer at that time your computer should be booting now from the CD ROM.
Cheers . . .
Feb 09, 2011 | Toshiba Satellite A105 Notebook
I have a toshiba laptop that on the bottom of the laptop it shows it to be an A105-S4184, model PSAA8U-SK7034, to my knowledge there has been no hardware changes but i did reload an operating system when a...
You need to make a bootable CD, put theToshiba DMI utility on the bootable CD; Boot from that CD, then run DMI utility to set the machine to match the designation on your recovery disks. That'll do it.
Jan 29, 2011 | Toshiba Satellite A105 Notebook
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
What is the maximum hrd drive capacity of Toshiba Satellite A105-S4164?
No reason why it shouldn't take anything that's currently available. Just be sure to get a SATA 2.5" drive.
Jun 29, 2009 | Toshiba Satellite A105-S4164 Notebook
Recovery console key convination for a laptop?
Hi there.
Restart the PC and hit F2 while it boots up, this will take you into the bios, look for boot devices and set the CD to the first boot device, save the changes and exit the bios. The compuer will restart and boot from the CD drive.
Once the OS has installed go back into the bios and set the HDD (hard drive) to first boot device.
Good luck and thanks for using FixYa!!
May 11, 2009 | Toshiba Satellite A105 Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Toshiba laptop a105-s4034
You need to set your CD/DVD/CDRW Disk Drive to Boot First. If the Second set of Recovery CD's don't work, Then they are the Wrong one's for that unit.
Feb 12, 2009 | Toshiba Satellite A105 Notebook
Laptop does not open windows
Boot to the WIndows XP CD, and at the first prompt, press R to enter Recovery Console. Once at the C: prompt, type CHKDSK /R and let the run, once finished, reboot and see if the system will boot.
If it still is in a reboot loop, or if CHKDSK reports unrecoverable errors, then you may have a hdd problem, run HDD diagnostics and see if you get a failure code.
If diags pass, try repairing the installation with the XP CD (Odds are fair to poor at fixing issue) if that fails try a clean install of XP (Sometimes that is the only resolution)
If the HDD fails diags or if all the above fails, replace the hard drive
Jan 26, 2009 | Toshiba Sattelite A105-S2051 Notebook
Toshiba Satellite A105-S4164 Notebook Logo
211 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
