Question about Microsoft Zune 8 MP3 Player
Zune doesn't turn on
I left my 8 gb zune attached to the car charger over the weekend and when i went to use it again the zune pad didn't work i tried turning the lock on and off but that didn't help anything i then tried to reboot by pushing back and up keys at the same time and that didn't work either but when i pushed back and down at the same time the zune went black and i haven't been able to turn it on again.
  • 52 Answers
The electricity power of the car watts its much higer the zune may have over heated the internal plastic pads send it to a expert to examine it
Posted on May 16, 2009
My Zune HD won`t turn on, what do i do ? =]
Hold the power button for 10 seconds. this should cause reset. if it does not hold it again for 15 seconds this should cause it to power into repair mode where you will then need to plug it into your computer and update the firmware with the included software. hope this helps!
Apr 15, 2010 | Microsoft Zune HD MP3 Player
My zune 8 gig won't turn on
find the reset button and use a paperclip to press down on the resset button. only for 10 seconds. if it doesn;t work then do it again and hold it for 30 seconds.if that doesn;t work hold it for a min. if that does;t work its fried.
Nov 15, 2009 | Audio Players & Recorders
8 GB zune, unplugged it while it was charging and it wont turn on
Try to restart the Zune using this procedure:
http://support.microsoft.com/kb/946064?sd=zune
If this does not work then you can try resetting it to Factory Defaults:
http://support.microsoft.com/kb/927001/en-us
Only do this if absolutely necessary, all content will be erased from the Zune. Not a huge deal if you have it all on your PC with the Zune software but still a last resort.
If neither of these work then you have a hardware problem.
Jul 25, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
8 GB Zune Problems
Try cleaning the switches and switch pads.
Jul 15, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune red 8 gb screen went blank and it plays the music but now i can't see what songs are playing or watch my videos. how can i fix it?
Something may have been attached badly on the inside of the Zune. Unfortunately this is a factory related problem. Is it still under warranty? You should send it in for a replacement.
Apr 08, 2009 | Microsoft Zune 2nd Generation Digital...
Zune 80G Freeze
I returned it to Ebay after calling Zune Tech Support to find out it was a dead battery or a battery that was not holding a charge.
Thanks but no premium plan needed.
Feb 18, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune Touch Pad Stopped Working
The same thing happened to mine where just the touch pad doesn't work. It happened after a few monthes and to one of my friends as well; hers started working a day or two after and I had left mine alone once it stopped working but I went back to mine after she mentioned hers started working again and mine worked again too. I know that isn't much help because I don't know what fixed it but try just leaving it off for a few days and then going back to it.
Feb 04, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune froze from using the wrong charger
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Rello 30gig zune need help
you can try and reset it by holding on the back button, and up on the d-pad. that should work it did for my 30 GB
Jun 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Open Questions:
Microsoft Zune 8 MP3 Player Logo
161 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
