Question about Whirlpool LER5636P Electric Dryer
Dryer won't heat.
I have an LER6620PQ1 that runs but does not heat I purchased it new in 2006.
    President:
  • 1,136 Answers
Hi, THe heating element is located in the back of your dryer. UNPLUG the dryer. Remove the back panel and you will see the element on the right hand side. If you have an ohms meter, check continuity on all the thermostats and the element. If any of them have no continuity, it will need replaced. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 16, 2009
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Why won't my dryer heat up?
There are several reasons for no heating on a Tumble Dryer. The heating element could be faulty ( open circuit.) There are several thermal cut outs which can also go open circuit The only way to check is with a Multi Meter by a qualified service engineer.
May 26, 2012 | Kenmore Dryers
The dryer works and heats up but it won't shut off
I believe that your timer has run out of time! ;) Seriously though, Your problem is more than likely your selector (the dryer timer knob) is worn out. Time to replace it with a new one.
Good Luck my friend!
Phillip
Dec 27, 2011 | Whirlpool Washing Machines
Dryer won't heat up, therefore won't dry clothes. good air flow from vent. not sure what part may need.
If your ELECTRIC dryer is still running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
IMPORTANT: Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Begin by verifying the source voltage at the receptacle and service breaker, and verify your power cord.
The reason a dryer may still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
NOTE: If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If you have questions, require additional assistance, please post back and let me know. I hope this helps you.
Aug 17, 2011 | KitchenAid KEYS700LQ Electric Dryer
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
Kenmore Dryer 65512 won't heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Whirlpool Dryer not heating
There is many different things it could be! most of the time it is not the heating element. You have thermal fuses and safety switches. I bet you 10 to 1 if you locate the thermal fuse on the element cannon say 1 foot up from the incoming voltage from the wires to the heating element.
1. either disconnect power to the unit, take continuity on every fuse try the one i suggested first.
2. the same exact fuse im talking about disconnect power and connect both wires together, dont ground it out, plug power back in and then try it.
Note this is only advice and Whirlpool Parts Surplus is not responsible. Try that give us a call or hit that link and find your thermal fuse part number.
Apr 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Dryer not heating
most likely heating eleament change you can find here as well as diagram http://www.partstap.com/ please rate me thank you for useing fixya
Feb 25, 2009 | Dryers
My Whirlpool, LER6620PQ1 dryer will not stop running, nor will it heat at all. What could be the cause? Since both issues began at same time, I would think it is a similar cause.
Try to put the dryer on a timed cycle and see if the timer will advance. If you have the dryer on an automatic cycle and it is not heating it can run for a long long time. If the timer will advance in a time cycle you may just need to check your thermostats and the heater on your dryer. To do this pull the dryer out and unplug it, then take the back off. You will need a voltage meter to continue. Check the voltage at the plug and make sure you have two seperate 110 volt legs and 220 volts across. If the voltage is correct check the heater for continuity and make sure it is not grounded. Then check the thermostat on the top of the heater housing. If all of these parts are good and you have the proper voltage you will need a new timer
timer # 8299778 $74.00 shipped to you.
heater # 279838 $63.00 shipped to you.
thermostat kit # 279816 $40 shipped to you.
Gool luck to you and let me know if you need a part.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Dec 02, 2008 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
307 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
