Question about Gateway FX7026 PC Desktop
SCREEN FREEZE-CHECKER BOX
When i log in on a user, within 1 minute the screen freezes in a checker box form with the colors smeared. This has happened over and over. Please help!
  • JDTec
    JDTec May 11, 2010
    Sounds like the video ram is bad or it may be the memory that is failing. If your unit has more than one Memory Dimm, try to boot it with with just one Memory Dimm to see if the problem s goes away.
    Let me know...
    Problem Solver:
  • 6 Answers
Reboot your computer and during starting type f 8 keys then start in vga enable mood then setup vga 1024 .
Posted on May 16, 2009
Out of nowhere got dizzy, weak, cold clammy skin, cold sweats, pale. within 30 minutes felt fine, color back
Sounds like heat stroke.But I would be unprofessional to try to diagnose you sight unseen just based on this information. Ah, I just spied your question was posted in the Health and Beauty section. It could be hormonal. See how quickly guesses can change! Information is king. You might get a clue from one of these symptom checker sites:
Symptom Checker from WebMD Check Your Medical Symptoms
http://www.mayoclinic.org/symptom-checker/select-symptom/itt-20009075
Jun 03, 2017 | Health & Beauty
Samsung hlr6167wx xaa
Bad main board part number BP94-01858A.
Feb 15, 2014 | Televison & Video
Samsung dvr 7162 need to reset password
please help me to reset password Samsung DVR SHR7162
Dec 24, 2012 | Samsung Shr-7162-15t Dvr Shr7162 Techwin...
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
I was playing arkam asylem and a bunch of blocks and lines appeared and it didnt freeze but the screen is messed up. my email is SERPATNTOUNG@yahoo.com some times also it has disc read error on a couple of...
This is called texture map error and the cause is a lose of stream
data form the G.P.U. to the ANA/ HANA video chip giveing you strange checker board patterns on some surfaces .
The G.P.U. will need to be resoldered and clamped to fix
this problem . before it red rings on you
Aug 04, 2010 | Microsoft Xbox 360 Console
How can i make my window media center work again .it always appear that it can not work again.
Try the system File checker tool! The System File Checker tool
To determine whether the issue that you are experiencing is caused by one or more system files that are used by Windows Vista, run the System File Checker tool. The System File Checker tool scans system files and replaces incorrect versions of the system files by using the correct versions.
To run the System File Checker tool, follow these steps:
1.Click Start, and then type cmd in the Start Search box.
2. Right-click cmd in the Programs list, and then click Run as administrator.
3.If you are prompted for an administrator password or confirmation, type your password or click Continue
4.At the command prompt, type the following line, and then press ENTER: sfc /scannow
When the scan is complete, test to see whether the issue that you are experiencing is resolved
see if this works!!!
Jun 12, 2010 | Computers & Internet
My xbox freezes in the middle of play and makes a funny sound. the screen looks like a checker board
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
Jan 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 freezing
There are two possible solutions to this issue. One the data that you downloaded either got corrupted during transfer somehow or during a resent save. You should delete all the iformation off your hard drive and start fresh. If this doesnt work try takeing off your hard drive and playing a game if it deosnt freeze you will need to either try the delete method or get a new HD.
If this doesnt solve your issue then it is very possible that your system is headed for the red rings of death. My system was fried after i had played assasins creed. It would freeze up and create this checker pattern on my back ground my system shortly after went red ring.
Dec 26, 2007 | Microsoft Xbox 360 Console
Gateway FX7026 PC Desktop Logo
171 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
