Blue lines that surround a face or broken lines across the screen
These lines can be best seen on light clothing and faces.This happens when the TV is in vivid mode. The only way to make them disapper is to select cinema mode which is a darker picture or lower the brightness. This is a Panasonic rear projection lcd tv. Appears to be the same problem that the Sony Wega rear projection TV has.
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiBlue lines that surround a face or broken lines ac - 0667c5f.pngnvergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set thatBlue lines that surround a face or broken lines ac - 9e7eb5b.jpgfluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
9e7eb5b.jpgTV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 22, 2009
SONY KLV32S400A - picture has become dark, faces on screen cannot be seen
Check the voltages that comes to the back light inverter, especially, the voltage from the main digital board that controls the brightness. If is found OK, be sure that the backlight inverter board is faulty. If not, the main baord. If you wish to get some details, check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 13, 2013 | Sony KLV32S400A 32 in. LCD TV
Lightnings like lines on a half screen
Must be of a back-light problem. Contact any service technician. This is not a user repairable fault.
Jul 14, 2013 | Samsung LN46B530 LCD TV
I'm getting a broken line across the top of the page when i print
try to align the printer heads, here how first you on the unit it print sample pages then face it on the scanner face down press the button scan wait till the power light stop blink then try to print again
Jul 31, 2011 | HP PSC 1410 All-In-One InkJet Printer
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
Green hazy lines across my projection tv screen
The coolant in between the CRT face and the focus lens has probably become discolored and would need to be drained, cleaned and refilled. The green CRT is the center one and it would have to be romoved in order to refill it.
Sep 20, 2009 | Philips 51PW9363 51" Rear Projection...
My Phaser 6120 leaves light lines across the face
Lift out imaging unit and look down and back toward you, may need flash light, and you will see a 5" x 1/2" piece of glass. Carefully wipe it with soft cloth. Toner gets on this glass and creates the streaks. Often means a bad toner cartridge is leaking toner. Ron
Jun 28, 2009 | Xerox Phaser 6120N Printer
Samsung LN-S4692D - Vertical lines (>15) & static on screen
this sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
May 16, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Bad picture. in wide
sir kindly adjust its screen focus of your tv,,, thankss and hope too help you,,,gud luck
Feb 25, 2008 | Televison & Video
Televison & Video Logo
241 people viewed this question
Top Televison & Video Experts
Electro Med Services...
