Question about Kenmore 63942 Dryer
Kenmore 80 wont start has power when start held
Kenmore 80 wont start has power when start held in I can here timer gizmo working Let go of start button nothing
  • 3 more comments
  • t_ball985 May 16, 2009
    Hi Vic model # is BD275E
    I'm sorry for the delay Vic (new to the inter-web) the model # is 100C628 12200 .tony
    Vic, model # is 110c62812200 Tony
    Hi guys gota go, I'll try tomorrow a/m thanks for everything tony
  • Dean Leatherman Jan 28, 2013
    If it is winter, the air flow safety switch might be frozen by air entering the exhaust tube from outside. To check, disconnect the exhaust hose and use a heat gun to backfeed hot air into the burner manifold. This should thaw the switch vane if it is hindered by frost or ice/snow entering from the outside or left over from the last drying cycle. Note if the exhaust hose is plastic you have to use low heat on the heat gun to prevent meling the hose.
    President:
  • 1,136 Answers
Hi, Sounds like you might have a safty fuse gone bad.
Get me the model# and I can help you further.
Thanks
Vic
Posted on May 16, 2009
  • 1 more comment
  • Victor
    Victor May 16, 2009
    I am sorry but that # is not coming up. Did you get it off the cabinet around the door opening? If there is a panel on the back that you canremove. You wil find the fuse there. If there isn't a panel in the back, you will need to remove the front lower panel. I want to help so let me know.
    Vic
  • Victor
    Victor May 16, 2009
    I am sorry Tony, that # isn't working either. Go to www.repairclinic.com and see if you can get it to work. please let me knwo. I want to help.
    Voc
  • Victor
    Victor May 16, 2009
    THis shows you need to remove the back panel. The fuse is located on the blower housing. It is /4" wide about 3" long and it is white. Test it for continuity. If it has none, replace it. This help?
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore Dryer Wont Start
The belt was broken and once replaced it worked.
Jul 06, 2009 | Kenmore Dryers
Kenmore 80 serirs dryer wont start..
hi..check your circuit breaker,may be the power cord
is tripping it.If this is not the problem,check and see if
there is a reset button on the outlet where you plug in
the dryer.
try this out..
thank u..
kindly rate my response..
May 15, 2009 | Kenmore 44832 Front Load Washer
80 series kenmore that doesnt spin anymore. It sounded like a motor was running but but the basket wasnt turning,not sure how to get to the belt to see if its broken.now i cant even hear the motor.
There is a small rubber gizmo between the motor and transmission, that transmits power bewteen the two, Looks kinda like a four leaf clover in a wierd sort of way. Its broken. They don't cost much.
May 06, 2009 | Kenmore Washing Machines
Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Kenmore 63942 Dryer Logo
246 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
