Question about Minolta EP1031/1031F CS/PRO Copier
Black marks on pages
Minolta EP 1031 dark marks are appearing on copies not in a stripe but like it is a roller that is dirty. there are two areas, worst is along left edge of A4 page then a lighter area about 10cm towards centre of page. About 3 1/2 repeats each page
  • Minolta Expert
  • 1,326 Answers
Can you stop the copy before the page gets to the fuser section? If you can and the doubling image is there you need to replace the drum cleaning blade and possible the drum as well. If the marks are there after the fuser section the problem is in the fuser. You will have to replace the Upper fixing roller. Good Luck... You may have a hard time finding the parts, this model is old and not a very popular copier..
Posted on May 16, 2009
My photocopying machine is sending me blank pages after photocopy
Minolta cspro ep 1031 My photocopying machine is sending me blank pages after photocopy
Jan 15, 2013 | Konica Minolta EP 2030 3000 Toner 2-410...
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
Black stripe across copy
The orange roller is probably contaminated from toner that is sticking partly to the photodrum in the cartridge. That roller is likely made of silicone rubber (heatproof) that presses the paper against the fuser roller to 'fix' the toner to the sheet.
I suggest replacing the cartridge and cleaning whatever is accessible before you put the new cartridge in.
May 04, 2009 | Minolta Office Equipment & Supplies
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Apr 10, 2009 | Canon IMAGERUNNER 6570 Copier
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
271 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
