Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Motorguide brute 67 "stuck on high"
Ok I just purchased this trolling motor and replaced the variable speed switch (witch was removed probably due to this problem). When the motor is hooked up 12 volt all the speeds work but hooked up 24 volt only runs on high (no matter the position of the switch). So is this something I can fix and if so does anyone know what it is?
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: The switch keeps burning out and the motor turns
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Posted on Jul 01, 2010
SOURCE: Ihave a motorguide brute hyper 67 trolling motor
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Posted on Oct 21, 2011
My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
Dec 16, 2015 | Boating
I have lost speeds 1 thru 4 on a minn kota edge 70. 5 still works fine where should i start troubleshooting
Hello Richard,
It has been some time since I have been around trolling motors but it sounds if the variable speed sensor or switch is either corroded or burnt out. Since you had the speeds and they are slowly disappearing it sounds if the switch is failing. If you are somewhat mechanical and know how to test using a volt ohmn meter you can check the switch this way to see if it is the switch. If the switch tests fine then your circuit board in the motor head or foot pedal has gone bad.
Hope this helps some
Oct 29, 2014 | Minn Kota Edge 70 45" - 1355970
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
Vitamix variable speed not smooth
Some models had a weakness with the variable resistance in the rotary switch but your description sounds more like the main PCB or even the motor both of which are very expensive parts to replace.
Nov 04, 2017 | Vitamix Blenders
Ihave a motorguide brute hyper 67 trolling motor can't get the 24 volts to work motor runs on 12 and 24 volts and all five speeds but don't have the thrust of 24 volts
Oct 20, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
My trolling motor stays on high speed all the time
Is the toggle switch on rabbit speed? If so it will go on fast as soon as u step on the pedal switch
Sep 26, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
555 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
