Question about Sony PlayStation 2 (PS2) Console
Controller port is not going back in
I just finished taking apart my ps2 and i accidentally pulled the controller port out of it. There is a mgnetic ribbon holding it right now and i need to find a way to get that ribbon to go back inside the mother board, i've looked around and the only guide that provides an answer for this is not free, so i'm going here first.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 273 Answers
This might help you. i hope it does. www.powerfulguides.com/ps2 go here and go to the very end :D
Posted on Jun 10, 2009
My controller keeps turning left on my PS3 and I can't take it apart.
YOU CAN TAKE IT APART. THE PROBLEM IS THAT ONE BUTTON IS STUCK.
IT IS VERY EASY TO FIX.
TAKE IT APART, REMOVE THE BUTTON, CLEAN IT AND PUT IT BACK ON.
THE ONLY TOOL YOU'LL NEED IS
http://cgi.ebay.com/THUMBSTICKS-BLACK-CONTROLLER-PS2-PS3-SCREWDRIVER-/170444552091?pt=Video_Games_Accessories&hash=item27af49779b
JUST $4. FIX IT YOUR SELF. YOU LEARN FROM DOING IT
PLEASE RATE IF MY OPINION HELPED YOU
Apr 12, 2011 | Sony PS2 Dual Shock 2 Controller...
No disc works for PS2
Hi, it sounds like your laser is either dirty or dead. first try to clean your laser with a Q-tip and some glass cleaner (no streaks that way). This will require you opening up your PS2. Take all the screws out of the bottom os it and pull the top off, be careful there is a ribbon cable that is attached to your power and eject buttons. You will be able to see your DVD drive. take all 4 screws out and take the top off. The laser will be right there. Swab the laser with the Q-tip and use the dry end to dry it off. Put the top back on and plug it in to the wall and your t.v. See if it will read the discs before you put it back together. If it won't then your laser is shot and needs replaced. But while you have it apart you can order a new laser for about $29.00 and install it while its apart. If it does read the discs then its fixed and you can put it back together.
Aug 09, 2009 | Sony PlayStation 2 (PS2) Console
Cant connect ALL instruments/mic to PS2 Guitar Hero World Tour?!
Yes, you can buy a PS2 Multitap Adapter. I had the same issue and just picked a mulittap adapter up on eBay for $8.50
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
My ps2 anolog dual shock controller wont work!
It could be the PS2 connector port.
1) Try cleaning it. Maybe used compressed air or just blow into the faulty connector port.
2) Something more challenging, is to maybe open up the PS2 and to search for any broken connections between the Ps2 controller port, and the Motherboard of the PS2. Use a phillips #0 or a phillips #1 screwdriver, flip the ps2, you will see all these tiny squares, pull them out using something sharp, and underneath them there will be the screws, also there are some screws located underneath the warranty sticker and another underneath the Info sticker, just probe the surface until you land upon a hole. there you will find the screws. Open the ps2 up and you will spot the connector and search for any broken connections. any broken links can be fixed just by using a soldering iron and some solder.( OPENING UP YOUR PLAYSTATION VOIDS YOUR WARRANTY).
3) IF your ps2 is still under warranty, you can send it back to sony, or one of their many repair centres around the nation( IF U ARE IN THE USA). If in another nation, you can visit sony.com and follow their instructions on how to go about with in warranty repairs
Dec 29, 2008 | Sony PS2 Dual Shock 2 Controller...
My PS2 controller port stopped working!
Sounds as if it has been dropped .....or an impact to the controller port while one was plugged in. in some cases the in side of the port can become full of dust and dirt causing light rusting creating a loss of connection ...but an impact can break a small chip on the back of the controller port inside the machine , try cleaning out the controller port and check to make sure the metal tabs are clean and un bent.
Aug 22, 2008 | Sony PlayStation 2 (PS2) Console
Help me
Hi Beth,
You need to take it apart, and get  everything back in its place.
REmove  8 or 10 Screw covers on bottom of your PS2.  open the case carefully, so as not to pull a cable loose from the motherboard. The Cd player cover needs to be removed to get your CD out. Remove 2 or 4 screws to gain access.  You could actually do this in less than 30 minutes. Go for it Beth
Oct 21, 2007 | Sony PlayStation 2 (PS2) Console
Mutlitap stand doesn't work
check And see if it is a problem with the make of your ps2 slim. thats all i have for you. my ps2 slim is brand new. i just bought it last year & it works perfectly. multitap is something i dont know about. i went to walmart the other day & a guy who was an expert with videogames told me all i need to know. Just look forward to that
Oct 04, 2007 | Sony PlayStation 2 (PS2) Console
Controllers
I would say either give the controlers to a specialist to take it apart or buy new controlers because mabye somthing inside is bugging up the controlers recive port
Sep 09, 2007 | Sony PlayStation 2 (PS2) Console
PS2 problem
It's likely the lazer lens is out of alignment or requires replacing. Did your dvd cleaner also have a lens aligning part to it, you normally go through a spoken instruction(go to track 2 etc), as cleaning is sometimes not the only required solution.
Jan 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
