Question about Goodman GDS80904BNA Open Flame Heater
2 yrs old, getting a 4 flash alarm , "Open High Circuit" any help?
Goodman heater model gdh80703axab, getting a 4 flash, "Open High Circuit" alarm. this is only 2 yrs old or less, any ideas? have voltmeter etc, any thing to check? thanks HVAC experts
  • scarys May 16, 2009
    got it, it just fired up, got a little cold here in Chicago suburbs, a few weeks ago I tried to start the A/C, Goodman also, that was installed last year, i think that the compressor kicked on out side, I know the cooling fan did, but the return pipe never did get cold 9 low pressure is the bigger pipe I think , right?) worked fine all last summer. could the open high also affect the A/c?
  • 116 Answers
Check for a reset able round limit switch in the burner area if fires up make sure filters are clean and no signs of flame roll-out in the burner area when fan comes on this furnace should still have mfg parts warranty left
Posted on May 16, 2009
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
Goodman # GMS81155CNA light blinks 4 times - furnance won't light and blower runs all the time - it's cold - please help
The 4 blinks means that the high limit switch or the regular limit switch are tripped... try to find the high limit switch... it is usually near the blower...there will be a red reset button in the center of it... push it in and the unit should work again...
if the regular limit switch is kicked you may have to replace it for the unit to work again...
This often happens after a power failure if the unit was running at the time of the failure. If you did not have a power failure, then find out why the limit switch kick out...
Here is a tip that will help you try to figure out why yourfurnace is not working.
BasicFurnace or Heating System Troubleshooting
heatman101
Apr 23, 2011 | Goodman GDS81155CNA Open Flame Mid-Size...
Tstat calls for heat, inducer motor comes on, ignitior glows red, gas valve opens, burners light for 5 or so seconds then go out, main blower will come on after first failure and continue to run, unit...
You are on the right track. I would suggest you change the sensor though as if it has failed it would be one of the reasons why it is shutting down the way it is as it cannot detect the flame and is closing the solenoid.
Hope this helps,
Best regards,
Dave
Nov 26, 2010 | Goodman GMS90703BXA Heater
Goodman model pgb030075-1 unit has led flashing on circuit board (1 flash) replaced open rollout switch unit heated for one cycle,won't refire makes three attempts then locks out
maybe the exhaust fan is not getting power, here is a website that should help, Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Nov 12, 2010 | Goodman Heating & Cooling
Its brand new never run and the fan turns on and flashes 4 red lights and it never tries to start
You need to check the limit switches with a meter...
What you are getting there is a classic lock out condition from an open limit switch....there could be two or three limit switches depending on make and model that you have there...
Something is open in the safety circuit...
heatman101
Oct 26, 2010 | Goodman GMS90703BXA Heater
My furnace blows cold air constantly even in heat mode. It's led light flashes 4 times in a set, what could it be?
On Goodman furnaces, 4 flashes usually means open high limit. Look for any burnt or loose wires or any resettable limits, they should have a red button that clicks when you push on it and wire going in and out of it with spade clips. If the open limit is not resettable, jump it out to verify its open and if that fixes the problem, replace the defective limit. Best of luck.
Mar 18, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Blower speed too fast
The furnace should be a 3 or 4 speed motor in it. On the circuit board there are places maked heat and cool. If you are looking for low the red wire should be plugged into the heat designation. make sure unit is unplugged before changing
Nov 22, 2008 | Goodman GMS80453ANA Open Flame Mid-Size...
Electronic ignition is not working on my goodman heater
it means the high limit switch is staying open , it is there to keep the unit from over heating. it have went bad , it is the small square peice with two wires going to it on the heat exchanger could be black or brown
Nov 11, 2008 | Goodman GMS90703BXA Heater
Model GMP100-5-REVA
You could have a limit switch that opened. On the reverse side of the furnace access panel there will be a diagnostic chart indicating what 4 flashes indicate. If it is an open circuit, why is it open? Did the unit get too hot and why? Unless you have the diagnostic capabilities, call a professional.
Jan 04, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
244 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
