Question about HP LaserJet 2430n Printer
Replace the tray 2 pickup roller assembly
I need to replact the tray 2 pickup roller assembly on an hp laserjet 2430, it is not covered in the manual
  • 1 more comment
  • coolc62 May 18, 2009
    I iknow how to replace the pickup roller. What I need is to know is how to remove and replace the whole pickup roller assembly.
    actually it is not related to my problem. I need to replace the tray 2 pickup roller assembly on a HP laserjet 2430 . You posted a reply explaining how to replace the tray 2 pickup roller. I already know how to replace the roller, what I don't know is how to replace the entire assembly. I cannot find it anywhere in the manual or elsewhere online.
  • coolc62 May 19, 2009
    I thought "replace the pickup roller assembly" was pretty specific. Do you know how to do that?
  • HP Master
  • 4,338 Answers
The tray two pickup roller is a roller in the front of the tray. Remove tray 2 and place it on a level work surface. Locate and open the cover that is
next to the roller in tray 2.
Pinch the blue latch that is on the left side of the roller. Slide the roller off of the shaft.
Then you can slide the new roller back in.
CAUTION When you install this roller, make sure that it locks into place. Verify that the
roller is correctly oriented, and that the round, black spacer next to the roller is correctly
positioned against the locking pin on the shaft.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
  • JDTec
    JDTec May 19, 2009
    This was not inappropriate. You were not specific on your question.
  • JDTec
    JDTec May 19, 2009
    yes. I will try to put it in written form for you.
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
HP LJ p2015 How do you replaced the feed roller on the 250 sheet tray? It is not in the service manual?
HP LaserJet P2015 Series Printer - Replace the pickup roller (tray 1)
  1. Unplug the power cord from the printer, and allow the printer to cool.
  2. Press the print-cartridge-door button to open the print-cartridge door.
  3. Remove the print cartridge.
    After removing the print cartridge, only handle it on the ends.
  4. Grasping the pickup-roller cover with thumb and forefinger, squeeze the left side of the pickup-roller cover to release the left retaining tab, and then slide the cover to the left and up.
    Failure to slide the cover to the left when removing it can cause the right retaining tab to break.
  5. Press the two black retaining tabs outward until the pickup roller is released from its seat.
  6. Remove the old pickup roller from the printer.
  7. Line up the black retaining tabs in the printer with the grooves in the new pickup roller, and then press the pickup roller into the pickup-roller seat until the retaining tabs click.
    Do not touch the pickup-roller pad.
  8. Grasping the pickup-roller cover with thumb and forefinger, insert the pickup-roller cover's right retaining tab into the retaining slot.
  9. Squeeze the left side of the pickup-roller cover and insert the left retaining tab in the retaining slot.
  10. Close the print-cartridge door.
  11. Plug the printer in.
Jan 29, 2014 | HP LaserJet P2015 Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
What does the HP LaserJet 2100 Series Maintenance Kit includes?
HP LaserJet 2100 120-volt maintenance kit, includes fuser roller assembly, transfer roller assembly, tray 1 & 2 pickup rollers and tray 1 & 2 separation pads.
Aug 12, 2010 | Canon Office Equipment & Supplies
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
Oct 21, 2009 | HP Color LaserJet 2600n Printer
Adf jam hp laserjet 3055
Here is a link to view or download the Service/Repair Manual. It details how to tear the whole thing apart if you need to.
Laserjet 3055
Sep 17, 2009 | HP LaserJet 3055 All-In-One Printer
I have a HP LaserJet 1320tn, after I changed the cartridge I keep getting paper jams just about where the paper meets the cartridge
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
Jun 29, 2009 | HP LaserJet 1320 Printer
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
Proper Manual cleaning
Hi Gidget,
I typically use "Chux" wipes and a shop-vac to start with. The wipes wipe up and REALLY HOLD the toner & paper particles, holds 'em tighter than a Hobo does a ham sandwich...
(I'll concede to the 'by-the-book' crowd that a specific (read EXPEN$IVE) type of vacuum cleaner is recommended by HP & most other service org's. I've used my shop-vac for 12+ years and have serviced thousands of HP LJ's, CLJ's, AiO's, MFM's, DJ's, OJ's, etc. I have never lost a single printer because I didn't use the 'right' type of vacuum...)
The Chux wipes are available from PartsNow, LLC; www.partsnow.com/.
They also carry maint kits for almost every HP printer made as well as Lexmark, Canon, Xerox, etc.
I use Cooper's Platen Cleaner (PartsNow) to clean the rollers using 2" x 2" gauze squares and nitrile gloves. Fedron works well too. HP's website mentions isopropyl alcohol and water as their recommended solvents. Use waht works best for you.
Having some 6-inch long cotton tipped applicators (wooden handled single ended Q-Tips...) helps tremendously.
In conjunction with the correct service manual, (in your case,  Combined Service Manual for HP LaserJet 4L / ML & 4P / MPHP Publication Number C2005-90988, August 1993), a thorough cleaning is very easy for almost anyone to perform.
PartsNow and several other websites have HP Svc Man's online for free, Google around.
A legacy utility from HP that I've not yet tried can print and cycle cleaning sheets to clean mainly the fuser, but also claims to clean rollers as well. HP printer specialists will recognize 'cleaning sheets' from HP's newer models, built in to the menu structure. The utility will allow you to do the same for older (LJ 4, 5, & 6) printers. Find it at:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=25484&prodTypeId=18972&prodSeriesId=25484&objectID=bpl03846
Another Combined Svc Man is available as well that covers:
HP LaserJet 4 / 4M
(C2001A / C2021A)
HP LaserJet 4 Plus / 4M Plus
(C2037A / C2039A)
HP LaserJet 5 / 5M / 5N
(C3916A / C3917A / C3952A)
HP Publication Number C3916-90984 (March 1996).
As far as Scheduled cleaning, the cleverly formatted (LOL) table below lists HP's recommended service intervals. Over the years, I've found that adhering to the schedule has reduced unplanned downtime by almost 80%!!
DESCRIPTION / QTY / EST. LIFE (pages) / REMARKS
1.  Toner Cartridge / 1 / 6800 (note 1) / When print becomes faint, shake cartridge to distribute remaining toner.
2.  MP (Tray 1) Pickup Roller Assembly / 1 / 200,000 / Replace roller and separation pad together.
3.  PC (Tray 2) Pickup Roller / 1 / 200,000 / Look for glazing and cracks.
4.  Separation Pad / 1 / 200,000 / Look for glazing and grooves. Replace together with Pickup Rollers.
5.  Transfer Charging Roller / 1 / 200,000 / May affect print quality and/or paper jams.
6.  Fuser Assembly (115 V, 50/60 Hz) / 1 / 200,000 / May affect print quality and/or paper jams. Look for marks on rollers.
6a. Fuser Assembly (220 V, 50 Hz) / 1 / 200,000
7.  LC (Tray 3) Pickup Roller / 1 / 200,000 / Look for glazing and grooves. Replace the Separation Pad.
8.  Exhaust Fan / 1 / 25,000 hrs. (I've only had to replace one in 12 yrs...)
Note 1: The estimated Toner Cartridge life is based on A4 or letter size prints with an average of 5% toner coverage, and with the density setting at 3.
Best of luck,
Foxfur
Oct 16, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 2430n Printer Logo
863 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
