Question about JVC AV-27530 27" TV
My jvc TV stays on about 3 seconds then turns off.
My JVC model 27530 stays on for 3 seconds then turns off. Sometimes I can get it to come on by unplugging it and plugging it up again, but it doesn't stay on. How do I fix this.
SOURCE: T.V WILL NOT STAY ON: JVC AV-27F702 27" TV
This sounds like a protection system cutting in. This happens if there is a major fault and continual use would lead to a fire risk.
Posted on Aug 09, 2007
premtech
  • 934 Answers
SOURCE: TV, i plug it in, turn it on, no image, "on timer" light comes on.
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Bill
Posted on Dec 07, 2007
  • 1694 Answers
SOURCE: JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Posted on Dec 11, 2007
SOURCE: JVC TV Model 32F476
test
Posted on Sep 11, 2008
  • 700 Answers
SOURCE: I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Posted on Apr 08, 2009
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Jun 11, 2010 | JVC AV-27530 27" TV
Tv won't turn on
You can try checkin the fuses I had a problem like that with my stereo receiver took it apart changed the fuses works great
May 06, 2009 | JVC AV-27530 27" TV
Number won't erase
Press the "DISPLAY" button. This may cycle through a couple of other displays but will finally clear the channel number. (That's how it gets turned on, too, by pressing that button.)
If this solution is what you needed, please take a moment to rate it. Thanks for asking here!
Feb 20, 2009 | JVC AV-27530 27" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
Cannot get 27" jvc av-27530 tv to recognize playstation 2
Do you have the remote? You will need to cycle through the inputs to get to video 1 or 3. You might have the buttons on the front of your tv that says tv/video or tv/vcr. If not go down the channels past 1 and it might automatically switch through the video input selections. For any of these solutions have the PS2 plugged into video 1 and turned on. Hope this helps.
Jan 04, 2009 | JVC AV-27530 27" TV
Goldstar TV (unknown model)
tv has a power supply fault requires service
Oct 22, 2008 | JVC AV-27530 27" TV
TV Value
under $100.00
Aug 04, 2008 | JVC AV-27530 27" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
High pitch crackle buzing sound when set turned on
Did you find a solution because I have the same problem on my JVC?
Nov 14, 2006 | JVC AV-27530 27" TV
JVC AV-27530 27" TV Logo
198 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
