Question about Leupold CASCADES 10X42 CAMO
Leupold Windriver Cascade 10x42 eyepiece jammed
Have pair of relatively new, & to date lightly used Leupold Windriver Cascade binocs. To view through them properly, I need to rotate & extend eyepieces out fully. However, now the right eyepiece is jammed and won't extend fully. Afraid if force it, they will break. Am I missing a relatively easy fix? If not, where can I send them for servicing that's known to be reliable and fast turn around. I hate to be without them in the middle of of bird migration. Thanks
    Sniper:
  • 73 Answers
Sounds like one of the eyepiece screws underneath the eyecup has come loose. The rotating eyecup is threaded underneath so it can rotate into up or down position on the eyepiece. If this is the case your Cascades are under warranty and it sounds like you should send them to Leupold to examine them. They are a very reputable company and I doubt they would put it down to user misuse if that isn't the case. Bear in mind that if you have been using them in the field and have had muck on them a small foreign object may have worked its way into the eyecup thread.
Posted on Jul 31, 2009
I have a pair of pentax 10x42 DCF HRc binoculars that will not focus properly througn the right eyepiece. Just wondering if this is a common problem and is it worhtwhile getting repaired
The binos will rack focus both at the same distance, you need to rack focus left side to distant image with left eye only, then turn diopter focus to focus right eyepiece. Diopter focus is thinner wheel behind focus wheel
Aug 15, 2015 | Pentax DCF HRc (10x42) Binocular
What I need is a phone number or email address for windriver binocular repair?
Windriver binocs are made by Leupold & Stevens in Portland (used to live just up the street from their plant). The contact info is
Leupold & Stevens 14400 NW Greenbrier Parkway
Beaverton, OR 97006-5790 USA
1-800-LEUPOLD
The website is ( Binoculars ) They don't seem to list an e-mail for contact, but you should be able to get help over the phone to start with. I hope that helps.
Good Luck!
Jun 14, 2015 | Optics
Where can I get a rubber eye cup for my Leupold 10x42 Windriver binoculars?
Hello there,
Might be an idea to contact nearest dealer via this page.
http://locator.leupold.com/
Sep 19, 2014 | Optics
Mis-alignement between eyepieces
Up close to the eyepieces around the barrels are small screws that you can use to "collaminate" your binocs. The screws aren't meant to be accessed by the owner and most manufacturers cover them up with the material that surrounds the binocs. Of course the binocs in their current state are useless anyhow, so I wouldn't hesitate to peel up the material to look for the screws. If you do it carefully, you can reseat the material anyhow. Then once you locate the small screws, put the binocs on a stand or a table outside. Focus on something far away using one eye. Then using both eyes, you adjust the screw on the other eyepiece while looking through the binocs. Adjust until you get a single image. You can use loctite, or nail polish to "glue" the screw in the final position if it is really loose.
May 07, 2009 | Nikon Action Zoom XL (10-22x50) Binocular
I am suddenly seeing double images theough my binoculars.
Apr 25, 2009 | Eagle Optics Energy (8x21) Binocular
When veiwing always see double image
Apr 14, 2009 | Optics
Out of focus
Assuming you are focussing correctly. When binoculars are out of collimation the most usual effect is double vision as the optical axis do not line up. The only thing you can do is to take them to a binocular repairer. The problem is the cost. Proper repair need the use of a device known as a collimator and it is a laborious task to do it properly. Your binoculars do not carry a high monetary value and a proper repair will cost more than a new binocular of similar specs. Porro prism binoculars mostly have the objective lenses set further apart than the eyepieces. This holds true except for reverse porro prisms which are the other way round. Roof prisms have both the front and rear lenses inline.
Make sure when you focus that the first eye you use to focus with is the one where the eyepiece does not have its own focus ring (dioptre). The dioptre adjustment is on either the left or the right depending on the brand. That eyepiece should be left alone until you have focused using the center ring. Then leave the center ring alone and focus the eyepiece that has the adjustment ring.
Mar 12, 2009 | Optics
Cabelas Alaskan Guide 10X42
I agree with you on that! I have a feeling they are either Nikon or Leupold sourced. The body is alot like green ring leupold ive seen but the lenses have a magenta multicoating on a lens surface which ive seen on nikon. I'm in the process of looking for the maker of them myself as I need an objective lens. I'm going to call the Cabela's Cust SVC number and see what they say. I've heard the new Euro styled binoculars are made by Meopta.
Nov 25, 2007 | Cabela's Alaskan Guide Binoculars
Double vision
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows: 1. Focus on a distant object. 2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view. Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields. Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
Jul 03, 2007 | Bushnell Powerview - Compact 10 x 25...
Optics Logo
385 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
