Question about Intel D102GGC2 Motherboard
Graphic Adapter high-pitched whistling noise
My adabter make a high-pitched whistling noise when gaming specialy on high frame rate and when on low frams its a sounf like a snake ssssssssssssss , this sound make ur head want to explode! plz if anyone has a solution need help badly
  • 1 more comment
  • ahmad_abulha May 25, 2009
    thanx for the reply lexisn_phoen but the problem not from my monitor i have bought the new LG w2284f 22 inch.
    im pretty sure its from my card... some say its the copacitor on the card board and i have to open it and put some kind of gell or somthing like that on the one making the noise . but im realy afraid to open a 400$ card.
    i hope u can benifit me thanx in advane
  • Dick
    Dick May 11, 2010
    There are two possibilities here. Your graphics card is faulty or your monitor is faulty. Run a game on your computer so the card is making the noise. Now turn off your monitor. Did the noise go away? If so, the problem is your monitor.
    If not, the problem is your video card. If your card is under warranty you should have it replaced. If it is not, do you have a plan for obtaining schematics and test information for the card? The manufacturer does not typically make that information available to anyone but an authorized service center.
  • Starfish Phoenix May 11, 2010
    Are you using an LCD screen or and older CRT? If your using CRT then I'm pretty sure its not the graphics card, It will almost definatly be the monitor
Fan making high pitched whistle
check for debris in the air intake. I've had leaves in mine make a similar noise
Nov 14, 2016 | Cars & Trucks
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
2011 Avalon high pitched whistle
I had that , and it was the transmission low on oil. Hope this helps.
Mar 20, 2014 | Toyota Avalon Cars & Trucks
I have a 2003 Jeep Wrangler that has a high pitch SQUEALING sound when I release the accelerator. Any ideas what's causing it or how to fix it?.
I know i have the same problem, and i also noticed than when i open the Hood the whistle just stops, so i figure out it must be some air cycling in or out osmewhere, I found out my air intake connected to throttle body was misplaced a weird gap was left open allowing air to whistle. u might wanna check there
Sep 19, 2012 | 2003 Jeep Wrangler
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
2004 honda odyssey making whistle noise
I know this original question was written quite a few months back but I was wondering if you ever found out what the high pitch sound was. I just purchased a used 2005 Honda Odyssey and it is doing the exact same thing. Any advice?
May 15, 2010 | 2004 Honda Odyssey
2004 ford freestar 4.2L engine...high pitched
this sounds odd but mine did this when i replaced the wipers. it seems the design of the wiper frame was making a whistle at higher speeds. the freestar wipers are exposed on the window cowl and not hidden so they endure the winds at high speed. it is worth a shot.
Apr 27, 2010 | 2004 Ford Freestar
Freezer unit makes whistling sound
This indicated obstruction of air flow. Is there a change in cooling temperatures also? Thanks, Sea Breeze
Mar 19, 2009 | GE GSS20IEP Side by Side Refrigerator
High pitched whistle
can u please rate my help? thanks you
Aug 28, 2008 | Daewoo DWC063R Air Conditioner
Intel D102GGC2 Motherboard Logo
254 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
