Question about Krups FBC5 1600 Watts Toaster Oven with Convection Cooking
Krups FBC5 unresponsive
Stuck on either time or "toast," buttons do not do anything. Unplugging does not help. There must be a reset on this thing. Anyone know where?
Had the same problem. I ended up taking it apart and cleaning the knobs. Wasn't to hard to do. Remove a dozen or so screws. Unplug the control board and remove it. Wash and dry all of the knobs and re-assemble. Worked great since.
Posted on Jan 11, 2011
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Door Replacement
  1. To fix a cocked door, open the door and loosen the screws securing the inner panel. Hold the door at the top and twist it from side to side to seat it securely on its hinges.
  2. Partially tighten the door screws; do not overtighten screws on a porcelain door because the surface may chip.
  3. Test the seal by inserting a piece of paper between the seal and the top corners of the oven. The seal should tightly grip the paper.
  4. To replace cabinet-mounted springs, remove the storage drawer and the oven door. Unhook and replace the springs. Replace both springs even if only one is broken.
Hope that helps..........
Jul 01, 2008 | Krups FBC5 1600 Watts Toaster Oven with...
The toast button does not work properly anymore, guessing there is something wrong with the contact?
My toast button did that for a while then got better. Also, try holding the button in for a few seconds instead of a fast hit.
Jan 27, 2012 | Krups FBC2 1600 Watts Toaster Oven with...
How do i set clock
You can get the manual on the link below page 9
http://www.krupsusa.com/NR/rdonlyres/932350FD-628D-4959-879A-AC006C96E9B9/7106/FBC4FBC5.pdf
• When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Feb 20, 2011 | Krups FBC5 1600 Watts Toaster Oven with...
Setting clock on krups toaster oven
buttons.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
How can I turn off the annoying "beep" on my Krups Toaster Oven?
Check out this link; might or might not help you:
http://applianceguru.com/forum1/15129.html
Please post whether this works for you.
Good luck, Sam
Dec 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Toast button sticks and sometimes does not function. Sometimes it will work if it is jiggled.
I had the same problem which was getting worse. Eventually I took the oven apart by removing the feet, shell and front. Then I removed the circuit board on the front panel which has all the switches on it. We never use the "Defrost" function, so using a soldering iron, I swapped the "Toast" switch with the "Defrost" switch. The Toast function now works normally. I plan to get some spare switches for the next time one of these goes wrong. While I had one of them out I checked it out and a Panasonic P/N EVQ-PAE05R available from Digi-Key P/N P12192S-ND looks like it will do the trick.
Oct 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Krups FBC5 1600 Watts Toaster Oven with Convection Cooking Logo
147 people viewed this question
Top Krups Toaster Ovens Experts
Stan Ford
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
