Slow start up
I have a SONY KV-F29SZ2 with snowy signal with colour bleed plus slow start up but the sound is ok.Is this because some cap or resitor short out thank you
techman
  • 3130 Answers
SOURCE: Sony KV 2084R
Is this set attached to cable?? have you tryed another set in this sets place first??? if so then the tuner on the sets probably bad but make sure the signals good on another set and not just on a default cable station on the tv like channel 3 or 4 .If another set looks crappy too then call the cable company.. if its on an outside antenna(do they still use those LOL)then see what others in the area are getting for reception. sorry My friend I cant answer any farther till you come back with more for me in my questions.
Posted on Mar 26, 2006
  • 18 Answers
SOURCE: Sony MODEL KV-2585 TV
You have your information incorrect, Q is not the designation for diodes, Q657 would be a transistor. First give us the correct number for the diode and how do you know it is shorted?
Posted on Aug 16, 2007
jerryg50
  • 1667 Answers
SOURCE: KV-28CL10U colour circles
There are two things that commonly cause the fault that you are describing. Below is the main one.
It is very possible that the degaussing circuit or the degaussing coil is no longer working. A common fault is that the degaussing thermosistor has gone defective and the CRT has become magnetized. The earth's magnetic field along with other environmental things cause the CRT's internal mask to become magnetized over time.
The thermosistor in most Sony TV sets is located in the power supply area. It looks like a little black square box with 3 solder posts on it. In some models it has 2 solder posts. After a number of years this part may fail.
When the power is first turned on, the thermosistor is very conductive. After it heats up, it goes very high in resistance. It drives a high decaying AC mains current through the degausing coil (located around the shroud of the CRT assy) for about 50 to 60 ms. It then allows the current to decay to zero over the next 50 ms. When you turn on the TV set, you normaly hear a kind of a loud thump noise. This is the degaussing action.
Once the degausser is serviced and is working properly, it may take a number of power cycles to eventualy demagnetize the CRT. After shutting off the TV, it takes about 20 minutes before the degausser can work again. The thremosistor needs some time to cool down.
If you are not experience and trained for doing TV service, I would suggest you give the set out to an experienced TV service tech to change this part. There are serious safety issues when working inside of TV sets.
It is possible to purchase a manual hand held degaussing coil. There is a proper procedure for using this type of coil. If you were to manualy degausse your CRT, you would have to do it on an almost daily basis. The manual degaussing coil is fairly expensive to purchase. It would be better to service the set.
The second thing that causes the CRT to show colour purity problems (color splotches, or circles, or patches), is that the mask inside on the face of the tube has become dislodged off its supports or became warped. This can happen if the set has been dropped, or hit hard enough to do some damage to the mask. I have seen this where TV sets were roughly handled during moving them.
The only fix for a damaged CRT mask is to replace the CRT. The cost would be as much or more than the set is worth. This is if you can even find a replacement CRT. Most all of the manufactures no longer manufacture replacement CRT's for consumer products.
Only specialized CRT's are still being produced on a limited bases for specific industrial and military equipment that must still be kept in service. These are for some types of radar, medical, aerospace, and other related industries.
Jerry G.
Posted on Apr 16, 2008
SOURCE: Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
Posted on Aug 05, 2008
jingjao
  • 252 Answers
SOURCE: Sony Trinitron Color TV - KV-27TS27 circa 1991
there,s a lose connection on vertical section of your tv. to resolve that to \resolder the vertical section but be careful of short circuit t may damage your system
Posted on Oct 19, 2008
Sony kv j14l1
If there is any blinks occurs to standby power LED during switch On, and the set switches off automatically?
Jun 01, 2013 | Televison & Video
Sony colour kv-xs521D vertical picture is short
Problem is in the Vertical output circuit: Output IC, Filter cap, or source voltage which comes out of high voltage area is low.
Need a schematic and to be able to test voltages etc in that area to find it.
May 24, 2012 | Televison & Video
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
The colour of our sony tinitron color tv model no.kv-xf21m83 has got fading (Red colour disappeared )and the indicator flashes red a number of times between 3 second intervals and the est is sparking
hi
this sounds as if the tube (crt) as a intermittant short in the red gun , try tapping the neck of the tube very softly with a screw driver handle, this just might just clear the fault
regards windyhouse
Apr 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Feb 28, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Picture clear then fades to snow when it does, makes annoying sound
sounds like poor solder on the ground conections of the tuner, depending on the age of the TV frostman
Feb 11, 2008 | Sony KV-27FS13 27" TV
Sony Wega
have you tried an external antenna?
Dec 11, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
Oct 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27V36 27"
sounds like you got a vertical foldover and could possibly be the vertical output IC but most likly its one of the waveshaper capacitors. This repair is one that alot of repair peeps swap out caps one by one to find the defective one and some use a cap checker but the right way is to use a scope to see the waveform aplitude and the shape of the waveform. This is not a user repair as this set will get repaired down to the componet level as np boards toreplace except for the sound. Take into the shop if you dont mind spending an average of 75 to 125 bucks for this repair Good luck
May 30, 2006 | Sony KV-27V36 27" TV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
