Question about Swift Science & Laboratory
I have a Swift Binocular Model 880. My son left the upper light on for 2 months. Of course the upper light does not work, however the light below the stage works just fine. I ordered a new bulb, however still no working upper light. Any suggestions? The transformer works just fine with the Stage light.
  • 139 Answers
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Posted on Jan 27, 2008
Dave Duff
  • 30 Answers
SOURCE: Microscopes
Well then ?
It sounds like you do have a pre-tension problem, and if the fine focus is slowly turning as the stage desends, that is where your problem is. If you could tell me make and model, fixing it should be no problem.
Regards.....Dave
Posted on Mar 10, 2008
  • 45 Answers
SOURCE: problem with MF-02 binocular microscope stage
I think your problem lies in the way the stage is limited upwards. On top of the stage, right behind it where it slides against the arm, there should be a little screw.  This screw limits the movement of the stage to a certain point upwards.  If the limit exceeds the adjustment gear and its opposing track, then the stage just goes up one notch and then it clunks down.  If you screw it down the stage is limited further down, if you screw it up it's limited a bit higher.  The point of this screw is to prevent objective and slide damage.  Try adjusting this little screw a bit further down and see if it still 'clunks' when you turn it up.  After that we may work on properly adjusting it.  If not, please post again with whatever detail you can provide to aid you with this problem further.
Posted on Jun 09, 2008
Ajkill
  • 2035 Answers
SOURCE: Nano not compatible with On Stage
Nano 3 rd generation is not compatible with the JBL on stage dock , you need to buy compatible dock to listen to music or if brought this you can get it exchanged to another dock which is compatible with the nano 3 rd gen..........
good luck...................
Posted on Jun 12, 2008
  • 12 Answers
SOURCE: Blower Motor not working
hello the problem your having with the blower motor sound like the blower itself the brushes could be worn out causing the extra load on the blower resistor you may need to have a blower motor installed hopefully you won't need the resistor hope this helps you
workitover
Posted on Jul 24, 2008
Adidas digital watch adp6042 i have press something and now i have offset when i try to set time on the left top button. How do i get it back to normal? Please help
To set the time for Adidas - Model ADP 6042
1. Hold SET/LIGHT (upper left button) for 4 seconds.
2. Press MODE (lower left button) to select the option that you want to change.
a. light
b. chime
c. 12/24 Day format
d. hour
e. minute
f. second
g. year
h. month/day or day/month format
3. Press the START/STOP (upper right) and LAP/RESET (lower right) to change the value for the options indicated in number 2.
4. Press the SET/LIGHT to save all the changes made.
Source: Allan T.
May 21, 2014
Feb 28, 2013 | Adidas Watches
The dimmer switch is not working it wont light up or dim at all put in a new light bulb
A good idea would be to check the wiring by taking it apart. if the wires are bad, you must get new ones and solder them to the light socket and the battery holder making sure not to cross the positive and negative wires.
Aug 04, 2011 | Swift M5S Binocular Microscope
Need 1 rubber eye shield for swift ferret model 747
Regards, Tony
May 10, 2011 | Swift Kestrel 826 (10x50) Binocular
Can you change a 3200 swift mono head with a binocular head and where can i find one
Yes, or providing they still make it. The monoc head is just held on with a thumb screw, and you can usually buy just the binocular head itself. You will most likely have to get the part through one of Swift Optical Instruments many distributors or dealers, but if you call Swift directly they will be able to direct you in the right direction: (877) 967-9438
Jan 27, 2011 | Swift M4002D Binocular Microscope
I hace a pair of swift ultra light binoculars and have lost 2 screws in one of the eyepieces. Where can I get replacements>
i would take one out of the other side and take it to a hardware store and see if i could match it up with some thing.
Nov 03, 2009 | Swift Ultra-Lite 762 Binocular
The right ocular will not stay in placewhen extended
you will have to be a bit more clear.....what make and model?
Aug 10, 2009 | Swift Audubon 828HHS (8.5x44) Binocular
Missing eyecup
Do you mean the Swift Audubon 8.5x44? If so, for the new model 820 contact Swift Sports Optics. If it's the older model 804 ask around in the forums such as Cloudy Nights. The new model 820 is rubber coated. The old models have a grey crinkle finish.
Jul 18, 2009 | Nikon Team Realtree Binocular
I have a Swift model 802, 7X35 binocular. The
at the bottom hindge there is a nut you can remove . then take a long thin screwdriver and take off the screw that holds the eyepiece focus shaft. turn center wheel till eyepiece xbars come off body,carefull not to touch lenses. gl larry@reichinstruments.com
Jun 23, 2009 | Swift Audubon 804ED BWCF Binocular
Right side brake light stays on all the time
Assuming you don't have a trailer connector the bulb failure warning module might be you problem
Nov 19, 2008 | 1992 Toyota Celica
Eyecups are sticking on my Swift ultra light binoculars
The rubber outer ring of the eyecups can be peeled off of the metal ring underneath. This exposes the three tiny screws and their channels that allow the eyecups to move in and out. Clean any debris out of the channels, tighten or replace the screws if necessary, and fit the rubber covers back onto the rings.
May 21, 2008 | Swift Ultra Lite 929 Binocular
Science & Laboratory Logo
225 people viewed this question
Top Swift Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Swift Science and Laboratory Expert? Answer questions, earn points and help others
