Question about RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun not firing
I disassembled my paslode framing gun,put it back together and it dosnt fire and do i need to oil piston shaft
    New Friend:
  • 121 Answers
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
Posted on Jun 23, 2009
Paslode 900420 fires only one nail and the battery has to be pulled and reinsert to fire again. After shooting one nail, the light alternate between green and Red. I have tried new fuel cell and fresh...
It needs to be cleaned and oiled. You can buy an electrical cleaner spray and oil specific for paslodes at Home Depot. You will have to take the back off (where the filter is) and clean it with the cleaning spray then oil it well. Put it back together and it will work like new again. You will be surprised how much difference it will make. Good luck
Sep 11, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Gun is only a few yrs old and has had moderate use. Problem is that when depressing the nose piece I get a hissing of air and it will not fire. It will sometimes fire but after a few nails it just hisses...
Your o-rings are wore out. Paslode makes(made) a Tool Repair Kit, PN219235 and Trigger Valve Kit, PN219224 for your gun. Always use all of the o-rings in the kit and liberally lubricate them before installing them using grease in the kit or nail gun oil. If the kits are no longer available you'll have to get a breakdown of the gun, (www.paslode.com/uploadedFiles/PowerMaster_Plus_Parts_Diagram_Schematics.pdf) and order all of the o-rings. Be very carefull to put everythng back together properly, you are working with a gun.
Aug 31, 2010 | NRS Paslode 501000 Powermaster Plus...
Not firing right
the nail return spring for the piston is stuck or broken,dis mantle the gun and clean and check the spring to see if its broken
Apr 06, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
The pin that fires the nail sticks and won't retract after firing. You can push it back in after it fires, but that is very time consuming. tried cleaning and oiling to no avail.
please go to paslode.com and take a look at the gun's schematic. you have one of two possible problems. check the compression on the pin's piston( it should have 2 metal rings) put the piston at the top of the chamber and let it go , if it drops by itself you may need new metal rings. the other fix is to replace your reed valve( it kinda looks like a comb with four fat teeth) sitting right under your muffler
Feb 10, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Oct 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
RTO PasLode 900420 Impulse Framing Nailer  Logo
1,839 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
