Hotpoint Aquarius 1000 WM62 motor problem?
When I start my washing machine it fills with water and all appears well but the drum doesn't turn. I've taken the top off and tracked a loud humming noise to be coming from the motor. Does this suggest it
needs replacing or could it need new brushes? Thanks for any help, cheers, NeilC
  • helen1971 Feb 28, 2009
    Water goes into my WD440 but the drum doesn't turn.
Hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Posted on Oct 31, 2009
    Problem Solver:
  • 4 Answers
The motor is shorting, it could be faulty brushes if you are lucky. Look at the wires in the plastic connector to make sure they are not sooty from burning. I had to rewire one on my machine.
Posted on Dec 17, 2009
Hotpoint aquarius 1000 extra
have you checked belt or brushes in motor
Jan 26, 2012 | Hotpoint Washing Machines
Hotpoint Aquarius 1000 WM62 The drum makes a screeching noise when turning ? Any ideas ?
it could be drum bearings or even some thing that has got past the inner drum and is jamed inside hitting the drum when it turns,,,,could also be the motor bearings,,,,open the door and try lifting the inner drum up,,if there is any lift in it then the drum bearings are going,,this will also cause it to screem on spin speed
Dec 01, 2010 | Washing Machines
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius 1000, model WM62, the drum will not go round at all, it is totally seized up, does this mean the motor has gone.
if the drum wont move even manuly u move it it is stuck the barings at the back of the drum have gone so it looks like you need to get it repaired cus it is a big job fixing a problem like you got.hope this helps
Mar 08, 2009 | Bosch Logixx WFR 2466 Front Load Washer
Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Nov 11, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
835 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
