Display polar cs 100
Hi
My polar cs100 speedo hrm battery went flat, new battery installed at shop. Display now reads 9999 and wont reset
  • 2 more comments
  • Anonymous Dec 21, 2007
    Same deal - replaced the battery on my CS100 and now it just shows "8000" and won't do anything else, now matter how many buttons i push and resets i do
  • cycle path Mar 14, 2008
    ditto, new battery and now the unit will not reset, display reads "9999" and when I push the left buttom the unit turns off and then comes back on and reads "9999"
  • mark_h8it Apr 18, 2009
    1 - changed battery,
    2 - hold 3 buttons per manual to reset - OK
    3 - press any button
    4 - Display goes to 9999 with no response other than repeat (2,3,4)
  • mowi May 17, 2009
    Same for me. Battery change on CS100, Display now always shows 9999. 3 Button Reset works, but aftwerward again 9999 on display. Any solutions yet?
SOURCE: Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Posted on Jan 19, 2009
escapement
  • 2334 Answers
SOURCE: Which way round does the battery go in a Polar FS1
Battry must go - (minus) into the movement and +(plus) facing up. As battery replacement must be done with watch upside down, you must see the +(plus) on battery when it is inserted into the movement and the fit the contact over it.
Do not forget to rate, please.
Posted on Mar 11, 2009
SOURCE: Polar CS 200 chest strap
For two years I had a problem where the monitor was presenting me with ridiculously high values, like 122% max heart rate. This typically happened on downhills or whenever I exceeded 25MPH (OK only downhills). One day when wearing a windproof vest, I noticed that it didn't happen. I then placed SaranWrap over the front of the chest strap to completely block the wind and it also worked. Then I discovered (while reading the Polar manual about HRM maintenance) that the problem might be that I rarely washed the unit. (Don't understand how this manifests itself as it does, but...) After I washed it as directed, the problem went away, so now I wash after most rides. Fast forward 4 months and the problem has returned, but usually only in the first part of the ride and I don't have to be going as fast. I dabbed on some water which didn't help and the next time added a few grains of salt to a few dabs of H2O. Problem still there. Now I'm trying the SaranWrap method to see if this will help, but as of yet, I can say that wrapping up only the central plastic part of the chest strap doesn't help. More experiments on the way.
Posted on Sep 14, 2009
Coachphil
  • 347 Answers
SOURCE: I am looking for a
The Polar S-410 uses the same watch band as all the other S-Series bands so you can replace with any of them. S120, S150, S210, S410, S520, S625, S725. S810 all work fine.
To get the exact replacement you can contact one of the Polar Authorized Service Centers, and they can send one to you, I seem to remember they are under $15-.
You can also change the watch band style entirely and go with a Velcro style sports band, they are readily available at stores like REI and other sports/ mountain type shops. Take your watch with you to match the width of the original band at the head.
Posted on Nov 19, 2010
ozark333
  • 396 Answers
SOURCE: Manual required to install beto child seat cs-100
Try this and see if it works for you. I think yours may be a CS-001.
Beto Child Seat Instructions
Posted on Apr 30, 2012
Polar AXN300 Heart Rate Monitor Watch HRM AXN300 is not showing pulse
I would think it is the sensor circuit in the watch. When you replaced the battery did you activate the processor all reset for the watch? I do not know on your model where or how this would be activated.
Electronic watches normally have a reset procedure for when the battery is changed. Very important the watch's processor reset is performed after changing the battery. This is not any of the user readings reset. This is a reset for the watch's processor and system. It is sometimes a contact that has to be shorted out with the jeweler's screwdriver, or it is a contact that has to be shunted, or etc., depending on the model. Maybe if you call the support for the watch they will tell you this. Normally they do not like the user opening the watch.
Feb 10, 2018 | Polar AXN300 Heart Rate Monitor Watch HRM...
I cannot get the computer to register miles when I hook up the system in my garage ...it's a cs100 polar cycle computer. It just stays at zero when I spin the wheel. I took it off my old bike where it...
The CS100 is designed to only work off the front wheel. if you are using a trainer where the rear wheel is spinning and the front wheel is stationary you will get no reliable reading. if this was the case on the old bike, you got lucky, the system is not designed to read that way. Too far a distance between sensor and computer.
If you are moving the front wheel, as on rollers, and you are not getting a signal than either the sensor and the magnet are not reading each other (too far away from each other, as an example) or the sensor has a dead battery, or you have the bike sensor turned off in your settings.
Jan 08, 2011 | Polar Cycling
Professional battery installation, doesn't turn on, is there a power on button? Or do I need to take it back and have them try again?
There are only a few Authorized Polar Service Centers. If you did not take it to one of these (which provide a 90 day warranty) they may have broken something or put in the wrong battery.
Polar and other HRM's are mini computers and actually quite delicate inside, they are not normal watches and while many watch repair places profess to be able to fix them, more often than not they cause a new problem. They are also repressurized with a special machine to keep them watertight, your watch is most certainly not watertight anymore and will eventually cause yoiu problems.
Too answer your question, no power on switch, if the battery install was good you would see a display. Take the watch back to the shop, and if they can not fix it, send it to Polar and then have the shop reimburse you for the repair. Polar will be happy to send them a detailed and Itemized account of what they had to fix.
Dec 03, 2010 | Polar FT40 Heart Rate Monitor Watch
I changed my wife's Polar F11 HRM watch battery. When I replaced the battery the entire screen lit up, everything. I let it sit for a few minutes and the normal screen came up. Kind of like it was "booting...
Try resetting. From the manual, "if there are no reactions to any buttons, reset the wrist unit by pressing all the buttons simultaneously for two seconds. All other settings but time and date are saved."
Is it possible the watch block is not in correctly and the display is getting squished?
Aug 03, 2010 | Polar F11 Heart Rate Monitor
Battery life poor
Check for cable corosion, and any bad ground or power on.
Dec 17, 2017 | Polar CS100
Intermittent failure of hr detection
Several issues with the Polar unit, 1 if it is in the cold the unit does not work properly. 2. If your layering yourself the unit will not work properly. 3, If the unit is not place properly on the body and there is not sufficient moisture, the unit will not work properly.
The best that I can suggest is make sure that you have sufficient moisture on your body, hold the polar cs100 near your body till it detects a heartbeat, the place back on the bike.
If your layering do to weather, you may not get it to respond till spring. I know what a waste.
By the way I had the CS 200, and I can't begin to tell you how many of my riding buddies had the same issue that your talking about including me.
The situation with polar rarely has to do with with interference but with a weak transmitter.
Oct 12, 2009 | Polar CS100
Polar F11 ''Scrambled/Smudged'' Display
You have to replace the battery with the new one. In most cases underpowered battery causes faded or even disappearing digits on LCD unless your watch has been damaged by water. Find your nearest watch repair shop or do it yourself. Do not forget to rate, please.
Jan 21, 2009 | Polar F11 Heart Rate Monitor
Hi, i have bought a bike with a polar cs100 computer attached,only for some reason can remove the display unit, please can you assist me on the save removal of the device.as i do not have any instructions....
Is it mounted on the handlebar? Try pushing down gently and then twist 90 degrees. It should come away from the bar mount. It attaches the same way in reverse.
Dec 27, 2008 | Polar CS100
Polar CS 200 chest strap appears to be sending signal to the HRM sporadically, and therefore heart rate displays zero. I changed the battery, but this did not help.
Just read that you need to wash the belt in a washing machine and/or check the snaps for corrosion. My 200sd is doing the same thing so will try this when I get home tonight.
Dec 07, 2008 | Polar CS200 Cycle Computer/Heart Rate...
Computers & Internet Logo
552 people viewed this question
Alun Cox
David Payne
David Payne
