Question about Sony RM-U306 Remote Control
RM-U306 Remote Control not working
Have changed batteries, made sure the receiver is on AV2, followed the tips on the manual about hold power, volume button etc....tried taking the battery out and holding the volume and channel down button....but still not working...need help please!!
4 Suggested Answers
SOURCE: For RM-YD023, I need to control my Receiver volume
I contacted Sony support for this same concern. Their response was that there is no volume lock option, you must switch back and forth from "TV" to "AMP" :(
Posted on Mar 05, 2011
SOURCE: my remote rm-u306 will not
I had the same issue. To fix it, on the receiver i pressed the Set Up button and then the Menu + button to change the input to C.MODE.AV2.
Reply
Posted on Mar 26, 2011
gopakumarg43
  • 74383 Answers
SOURCE: Sony remote control GD001 - volume control doesn't work
Your remote control need cleaning.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 700 posts to different brand TVs now.
Pull up older posts there. Cleaning procedure to remote control is given in detail.
Posted on Sep 11, 2012
I lost my remote for my Sony stereo STR DE845
You need a Sony RM U306. Many sources. One here: http://www.amazon.com/s/?ie=UTF8&keywords=rm-u306&tag=googhydr-20&index=aps&hvadid=27053616723&hvpos=1t1&hvexid=&hvnetw=g&hvrand=12329541754225110903&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_8osjhf6p86_b
Apr 11, 2015 | Sony Audio Players & Recorders
Receiver Volume Control
TRY UNPLUGGINH THE UNIT FROM WALL PLUG SOCKET FOR 10 MINS THEN TRY AGAIN
WWW.GENUINEREMOTES.CO.UK
Mar 18, 2014 | JVC Remote Control RM-SRX888J...
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
Oct 18, 2011 | JVC AV-27850 27" TV
I have a Sony Bravia TV, only a year old, had several power outages and suddenly RM-YD028 TV remote is not working at all. On the Dish network remote, the satellite controls are working, but not TV...
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
May 31, 2011 | Sony RMYD028 Remote Control
For RM-YD023, I need to control my Receiver volume while in TV mode. I can control my Sony Receiver while in AMP mode, but cannot change independent volume control so that I can keep the remote in TV mode...
Jan 29, 2011 | Sony RM-YD023 Remote Control
My remote rm-u306 will not turn on my system but it will turn it off when i press the stand by button and the off butten together
Reply
Jan 28, 2011 | Sony RM-U306 Remote Control
Need remote,"Sony AV system2", STRK740P
You need following remote for STR-K740P
clear_spacer.gif 147720411 RM-U306 REMOTE CONTROLand it is available, click Sony Accessories Store, for $35
May 12, 2009 | Sony STR-DE625
Direct TV remote code for yamaha rx-v463?
It is 30376. The trick to discovering, is to turn the receiver off, first. Then it will power on when you input mute/select 30376. Then you can program the DirecTV remote to adjust volume (in AV2 mode only or in all modes). However, it will only power up the receiver. It has to be turned off with the original remote or at the receiver itself.
Feb 09, 2009 | Yamaha RX-V463 Receiver
Sony av remote
To reset the remote control to the factory default settings, simultaneously press the POWER , TV/VIDEO , and VOL- buttons. Go here for programming instructions; http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMPP412
Sep 03, 2008 | Sony (RM-SP50) Remote Control
Remote
I have found a solution to the question. This remote will allow a user to control a SONY receiver by pressing the "Use Mode Key" at the top of the remote, and AV1 or AV2 button, in the first line of buttons toward the top of the remote, at the same time and this allows for control of an unlimited number of SONY receivers
Jan 15, 2007 | Sony RM-PP411 Remote Control
Televison & Video Logo
306 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
