Question about Refrigerators
Amana frig model #TCI18A3L is not running
Due to a mishap while testing the ice maker, the frig apparently got shorted out and no longer is running. I was wondering if there is a reset switch somewhere maybe in the back?
  • jenztalkn3 May 16, 2009
    It said to test the voltage at 2 test points on the ice maker, then to short two other test points with an insulated wire to see if the ice maker motor started.Apparently the two test points that were shorted were the wrong ones, because it went POP, and everything shut down.
  • Victor
    Victor May 11, 2010
    THere are no restets on a refrigerator. Are your lights on? How long have you left it on after testing the icemaker?
    President:
  • 1,136 Answers
If the lights are of too, you tripped the breaker in your house. Check and see if you have a ground fault plug near by also. Do you have refrigerator lights?
Posted on May 16, 2009
Not enought water to ice maker
Can you provide a make & model # for the unit?
Feb 08, 2014 | Refrigerators
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
Ice maker no longer works. hose was replaced due to a hole. it still does not make ice. water seems to run through the hose and frig though. now the hose has come unhooked. would appreciate your...
not sure which hoes / the one that goes from water valve up the back to the icemker . this one can become blocked with ice and it will leak out the back and no ice . ( thank you for the model # . i looked this model up / but if no ice ck the valve .. mm
Oct 31, 2010 | Amana ARS266ZBS Side by Side Refrigerator
I woke up this morning to a flooded kitchen due to the ice maker, in my Amana refrigerator, not making ice and just pouring out water. What is the problem?
Either the switch in the ice maker is stuck keeping the valve open or the valve has stuck. Unplugging the frig will tell you which it is. If the water stops when the frig is unplugged it is the switch. If it does not then it is the valve.
Eric
Dec 12, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
11 year old amana frig icemaker
you most likely have a short in the ice maker ..the ice should be ejected before the water is call for... you need a new ice make or if you can change the ice maker head let me know and I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
