Question about Canon Office Equipment & Supplies
Model pc6re alternates E0/00 in the number window after warmup.
This is a Canon copier. Nothing can be changed or selected.
Thanks
Jim
  • Canon Expert
  • 1,326 Answers
You will have to replace the thermister or the thermal fuse or the fuser heating lamp or all three. I don't believe it can be cleared till the problem is fixed. Most of the time you will need to replace the fuser lamp... It's a older copier and the lamp is most likely blown... Good Luck
Posted on May 16, 2009
What do I do if the machine stopped working showing the error code E000000
That error code means your Canon failed to warmup properly. Could be a bad Fixing assembly. Sometimes it is possible to just reset the code and then you may continue to use the machine. Based on the error code you provided, I assume you have a Canon but you need to post the model number to receive more detailed advice.
Sep 17, 2014 | Office Equipment & Supplies
I have purchased a Canon printer with model of MX380 for a number of years. Now I have purchased a notebook recently with windows version of W7. Would you please advise me that whether the printer can...
Canon may have a Windows 7 printer driver for this model printer.
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Sep 06, 2011 | Canon Office Equipment & Supplies
How do you change the resolution for scanning?
  1. Launch MP Navigator EX.
  2. On the Windows desktop, double-click the 'MP Navigator EX' icon.
  3. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator EX' folder, then 'MP Navigator EX' icon.
  4. Click 'Photos/Documents (Platen)' on the Scan/Import tab.
  5. When the Scan/Import window is displayed, check Use the scanner driver, then click Open Scanner Driver.
  6. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    To set the resolution in Simple Mode:
    (A) Select the 'Simple Mode' tab.
    (B) In Destination drop-down, select the resolution which suits the purpose.
  7. To set the resolution in Advanced Mode:
    (A) Select the 'Advanced Mode' tab.
    (B) In Output Resolution drop-down, select one of the preset resolutions, or enter a number from 25 to 19200 to specify your favorite resolution.
    In either Simple or Advanced Modes, select other settings as required and then click 'Scan' to start scanning
Let me know if you have any other questions. Thanks.
Jan 13, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon pc6re manual
you may download from " http://software.canon-europe.com/"
Sep 08, 2010 | Office Equipment & Supplies
I have a canon pc6re copier. I used a compatable \...
I'm guessing you used a compatable toner/drum cartridge. It sounds like you have a bad cartridge. If its a refilled drum cartridge its bad, either the drum blade is bad or charging is bad. Take it, or send it back and get another one. I recommend genuine "Canon" products. All toners and units are not made to the same standard as the Canon products.
May 18, 2010 | Office Equipment & Supplies
Error message E 904 flashing alternately on screen
Cassette Feeding Module E904
  • The waste toner box swing cam home position sensor is faulty.
  • The cassette relay PCB is faulty.
  • May 29, 2009 | Canon C210 Copier
    Canon PC6re copier makes copies that are dark on the long edges
    Just fyi, a Canon PC-6e is a copier that is about ten + years old of a model... The drum unit will make the copies better.... But, you most likely need to clean the optic's. Have you tried to make the copies lighter??? If I am correct, there is a small botton on the control pannel that will turn... It will make the copies light one way and darker the other way... Good Luck
    Apr 20, 2009 | Canon PC170 Copier
    I changed the ink in my canon ip1800 and now it the me the print head need alignment and i don't know how to do it.Can you help
    1. For Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes
    2. Select your printer model name icon.
    -> Printers and Faxes.
    3.Open the File menu and select Printing Preferences.
    The printer driver setup window appears.
    4.Click Print Head Alignment on the Maintenance tab.
    A message appears.
    5.Set the paper thickness lever to the left, and load a sheet of A4 or Letter size plain paper into the auto sheet feeder.
    6.Follow the instruction in the message.
    7.The Print Head Alignment dialog box opens.
    Select the numbers of the patterns with the least amount of streaking in the associated boxes.
    Clicking the patterns with the least amount of streaking in the preview window, will automatically set their numbers in the associated boxes.
    8.When you have entered all the necessary values, click OK
    And that should do the trick for you.
    Sean
    Feb 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    Changing ink cartridges
    Hi.. Log on to the Canon website.. The printer manuals are in PDF Format at their site.
    Thanks
    jim
    Feb 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Canon iP1800 Driver for Windows 98
    • click here
    • Select your product, model no. etc.
    • And make download.
    Thanks
    Iqbal
    Apr 26, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    65 people viewed this question
    old marine
    old marine
