Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Pink screen After a year and a hlaf of owning the 50v500. I have the pink screen problem but it comes and goes, sometimes for 5 minutes, sometimes alot longer
  • redruby Aug 09, 2008
    I have a pink blotch area about 1/4 the size of my screen. Any picture within that area is distorted. Outside of that area appears fine. I called Hitachi and was told that they would not help out on a TV that was 4 years old. Another shop told me to replace the light engine was somewhere around $1000. Hitachi told me to call Sears, which did not sound like a real good answer to me.
  • 927 Answers
Good Day,
TRY THIS:
Before you attempt any repairs, it is necessary to make a test. The results of this test will determine which part may need replacing. Please follow the directions.
In short, you will be doing the following:
  1. Perform Memory Initialization. NOTE: You must write down some data values before performing initialize. (See Below for Procedure).
  2. Check this status of the picture. (See Status after Initialization)
  3. The status will determine what part need replacement.
FOLLOW THE ORDER BELOW:
(01)
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS: (See Below)
Select a non-used or blank Video input or tuner to get into I2C menu, also make sure the Power LED on the Front of the set is not blinking at all.
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button.
  3. Then press the POWER button for two seconds.
    • You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
    • If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
(02)
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It's important to write the values down before proceeding.
H Position: ________
V Position: ________
LCD ADJUST (NOT LCD DRIVE) (Arrow right)
GHOST (Arrow right)> LCD ADJUST =SHP: _______
(Press Select) LCD ADJUST GHOST=R: _______
(Press Select) LCD ADJUST GHOST=G: _______
(Press Select) LCD ADJUST GHOST=B: _______
(Press Select, then Exit)
V COM (Arrow right)> V COM-R: Set For Minimum Flicker
(Press Select) V COM-G: Set For Minimum Flicker
(Press Select) V COM-B: Set For Minimum Flicker
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice).
I hope this was helpful, big IRISH.
Posted on Aug 12, 2008
Possibly a bad light engine (not cheap).
Posted on Oct 26, 2007
My sony dsc wx9 has a pink screen. One minute it worked fine, I set it down for one minute, picked it up to use and the screen was pink.
Tap the screen next time it goes pink, see if it changes, you may have a bad viewfinder LCD panel.
Nov 15, 2014 | Cameras
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
The screen is pink
You CCD-chip is giving up it's ghost.
DIY-repair possible, but Fuji refuses to sell chips.
Jan 23, 2009 | Fuji FinePix S5000 Digital Camera
Pink Screen
Most likely the green electron-gun in the CRT is failing.
Jerry G.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Your light engine is going out. You might be able to get a rebuilt one fron www.vancebaldwin.com
Feb 01, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink cloud covering most of the screen
If the pink spot appears as mostly a circle in the middle if the screen then a light engine is needed. If it is an even coverage than possibly just a memory initilization needed by a technician.
Jan 13, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
216 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
