Question about JVC AM FM CD DET FACE CAR STEREO
Stereo hook up plug black and red wire has power via circuit test. When plugged into stereo the stereo will not power on. If I touch one of the speaker wires to the red wire it turns on. Anyone able to tell me what I need to do to fix?
  • 245 Answers
You also need to check for power at the yellow wire it should be +12 v unswitched which means power all the time wether key is on or off the red is +12 v switched and black is -12 v
Posted on May 16, 2009
Heater will not shut off it will run 24hrs. even when temp. is above heater setting
seethis procedure and fix it. God bless you
    • 1 Connect the test leads to your DMM. Insert the black lead in the black "common" socket and push the red lead in the red socket labeled "volts, ohms, milliamperes." Set the function switch on your DMM to the "ohms" function.
    • 2 Use a Phillips head screwdriver to remove the space heater's back cover and disconnect the power cord from the switch and heating element
    • 3 Check the power cord for a broken wire. Touch one test probe to first one blade, then the other blade on the plug and then touch the other probe to the other end of the power cord. If the wire is working, there should be an indication of 0.00 to 0.5 ohms between each blade on the plug and a different end of the power cord. If the meter indicates "O.L." on one or both sides of the cord, the wire is defective. Most often, the wire will be broken right at the molded plug or inside the plug. The easiest way to fix this problem is to replace the cord set.
    • 4 Check between the two sides of the power cord for a 0.00 to 0.5 ohms reading indicating a short between the two sides of the line cord. If the heater tripped a circuit breaker, there is a short circuit somewhere in the heater wiring. Shorts in a power cord usually occur inside the molded plug. The short could be inside the cord set, if it has been pinched or cut. Fix by replacing the cord set.
    • 5 Check the thermostatic switch by placing one test probe on each of the switch terminals. Turn the switch slowly through its complete range. The DMM should indicate a continuous 0.00 to 0.5 ohms throughout the switch's full range of movement. An "O.L." indication here indicates a faulty switch, and you need to replace it. The reason that a functional switch could read 0.5 ohms and not 0.00 ohms is that some DMMs read their internal fuse's resistance.
    • 6 Check the heating element for an open circuit or short circuit. A typical radiant heating element will have a resistance of roughly 15 to 30 ohms. A burned out heating element will read "O.L." and need to be replaced. A reading significantly lower than 15 ohms indicates a shorted or partially shorted heating element, and it needs to be replaced.
    • 7 Reconnect the wires that you disconnected earlier and plug the heater in. Check the blower motor voltage if the heating element gets hot but the fan does not work. This is the only test that you will have to make with the heater plugged in, so use caution here.
    • 8 Set the DMM for "AC volts" and touch the test probes to the motor leads. A reading of 115 volts here indicates a defective fan motor, and you need to replace it.
Sep 30, 2012 | Comfort Zone CZ1500WC Infra-Red...
Make extension 220 volt cord for 220 volt welder
most 220v welders have a NEMA 10-50 plug or the NEMA 6-50 plug--the input /output ratings thru recepticle and thru plug are same-configuration of plug prongs are different( Grainger Catalogue shows simularities and differences) main difference is AC Horsepower Ratings are different, and that applies Only on equipment that uses 3 phase, not your welder.Use an Ohmmeter to touch unpowered wire connection under shroud at ground and plug prong, then red power connection to corresponding plug prong, and again to black connection and plug prong,mark them w/ felt pen w/ corresponding colors (Green, Black Red). Change out wire plug to fit into dryer or stove recepticle, or make an extention adapter plug witch fits stove recepticle and extends out thru floor to carport and goes to 10-50 recepticle-whereas ground green goes to W position (Center) Y is Black and goes to Y Black, X is Red and goes to X red and cap off the white neutral coming from plug -welders and hot water tanks do not return unused electrcity via the white neutral (return) wire--they use up what is available on demand in heating elements or in welders - the electromagnetic field.GET HELP DOING THIS, by someone who has knowledge, SKILLS and EXPERIECE. I have 1 welder fitted to go into dryer plug which has 14-30 recepticle, and i have 1 where i kill stove circuit at panel, unplug stove, plug in 14-50 plug which has a 10-50 recepticle on other end, plug in welder 10-50 -p, flip cicuit breaker switch to on-welder has full power range capacity. No oven in use while welder going--but probably wouldnt run it anyway if on different circuit.Any doubts whatsoever--anything not 100% clear--DO NOT DO THIS or any other Electrical Manipulations--have a licensed electrician stub in a secondary circuit breaker off your main if load is acceptible and have him wire in the recepticle which your plug will fit into---.
May 31, 2012 | Craftsman Welding Tools
Hooking up a kenwood mp235
Blue/White - Power Control/Motor Antenna Control Wire
Brown - TEL Mute Wire
Blue - ANT. Cont. (Not Used)
White/Black - Front Left Speaker -
White - Front Left Speaker +
Gray/Black - Front Right Speaker -
Gray - Front Right Speaker +
Green/Black - Rear Left Speaker -
Green - Rear Left Speaker +
Purple/Black - Rear Right Speaker -
Purple - Rear Right Speaker +
Red - Ignition Wire (Switched +)
Yellow - Battery Wire (Continuous +)
Black - Ground Wire -
Here is a copy of the User Manual:
http://www.masterspas.com/manuals_av/Kenwood_KDC-MP2035.pdf
Jul 22, 2010 | Kenwood KDC-MP235 CD Player
I need a circuit diagram for a 2000 Hyundai accent sterio plug. ie colours for speaker wires, power, ign, dash lights etc.
speaker wires you can connect one at a time to see which is which as for the others black is earth, red is usually ignition, yellow is constant power (memory) and sometimes you'll have a blue wire for power out or you can usually just buy an adaptor plug to suit most stereos
May 18, 2010 | 2000 Hyundai Accent
I am trying to hook up an aftermarket stereo to my 2008 mitsubishi lancer. the wiring harnesses (metra 70-7005 and mito-02) that i have do not appear to line up with the mitsubishi wiring. when turned on,...
Power to most radios is the red wire and ground is black. Do not mix up the two and make sure your plugs match "red for red" and "black to black" (the ground some times will also be green). If not you can blow a fuse in your box which you might need to check. If you have a meter you can check your car harness plug to see if you have 12 volts on your red coming out. If not make sure your fuse is good and you have the power on in the car (key turned backwards on most cars will power the harness if not turn if forward like you are going to crank it. If you are not sure the radio is good, you can pop the hood of your car and hook up the red wire from the radio to positive side of the battery cable and the black to the ground side of the battery cable and you should be able to turn the radio on. If you see it power up, you will know your problem is in your harness. Hope this helps
Oct 02, 2009 | 2008 Mitsubishi Lancer
Jenn Air cooktop has 4 wires Black, white, red, and green and my house supplies power with 3 leads white, black , & green. How are the wires hooked up to power the unit?
Old plug: green is ground, white and blace are both hot power. New cooktop: green is ground, WHITE is COMMON, black and RED are hot power. You are going to need an electrician to run a new circuit and plug for your new cooktop.
Aug 31, 2009 | Jenn-Air JED8230 Electric Cooktop
Stereo Wiring 1984 VW Rabbit
The red wire is power, brown is ground. There also may be a second power wire (possibly yellow) that is switched though the ignition (test this with a light), if you hook it up that way you won't drain your battery by accidentally leaving the stereo on!! The best way to determine what wires go to what speakers is to take each pair and brush the ends across the ends of a "D" cell battery! the corresponding speaker will produce a bit of static! The wires with the stripes are the negative side of each speaker circuit. Hope this helps...;-)
Apr 08, 2009 | 1984 Volkswagen Rabbit
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
How to test unit without hooking up to vehicle.
You can connect the + and - from the stereo to a 12 volt DC power supply, or a step down transformer to test out the functionality.
Best of Luck.
Oct 24, 2007 | Jensen VM9510 Car DVD Player
JVC AM FM CD DET FACE CAR STEREO Logo
520 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
